I am receiving this message each time I upload my iOS app to iTunesconnect:
Dear developer,
We have discovered one or more issues with your recent delivery for "Guitar Scales.". To process your delivery, the following issues must be corrected:
Missing Info.plist key - This app attempts to access privacy-sensitive data without a usage description. The app's Info.plist must contain an NSCalendarsUsageDescription key with a string value explaining to the user how the app uses this data.
Once these issues have been corrected, you can then redeliver the corrected binary.
The App Store team"
and I don´t find a clear answer to this issue in the forums.
I just find similar questions with no reply from Adobe. Why isn´t there a reply from Adobe to this issue?
Can somebody help me?
Best
The description of why you want to use a given feature is a recent requirement from Apple. It's the text that appears in a dialog the first time the user invokes that ability. You have to say to the user why it is you need to access that feature.
In the app-descriptor xml there is a section called InfoAdditions, in the iPhone section. That's where you'll see UIDeviceFamily, that has a 1 or 2, or both, depending on what devices you published for. You ought to be able to add this as an entry there:
...Copy link to clipboard
<key>NSCalendarsUsageDescription</key><string>Guitar Scales uses your calendar to book your next gig.</string>
One difficulty is that Animate wipes out that setting when you go into publish settings. A way around that is to only add the extra text to the XML at the end, and then do a Publish from the File menu. Don't go back into publishing settings, it will erase your changes to the XML.
I just tested it, and info.plist did have a NSCalendarsUsageDescription key, and the text was set to "Guitar Scales uses your calendar to book your next gig."
Now, if you can't think of a reason why your app would be accessing the calendar, then look at any ANEs you are using, and think about whether they might have a reason to look at the calendar. If you can think of a reason, then describe it in that string.
Hi Colin:
Thank´s a lot for your reply.
I have an ad-free version than went up to iTunesConnect with no problem. The one that I can´t get up is the one that uses the MmgAdMob_both_ANE_v4_7_0
I don´t know of any reason for this ANE to look at the calendar, so I really don´t know what to do. This is what I have in my XML.
I will appreciate your help:
<iPhone>
<requestedDisplayResolution>standard</requestedDisplayResolution>
<InfoAdditions><![CDATA[
<key>UIDeviceFamily</key>
<array><string>1</string><string>2</string></array>
]]></InfoAdditions>
</iPhone>
<supportedLanguages>en</supportedLanguages>
<extensions>
<extensionID>com.milkmangames.extensions.AdMob</extensionID>
<extensionID>com.milkmangames.extensions.GoogleServices</extensionID>
</extensions>
</application>
Again:
Best Regards,
Email support@milkmangames.com to ask why the ANE is reading the calendar. I think you'll still have to try the InfoAdditions changes I mentioned, but it would be nice to know what reason you have to give for accessing the calendar.
You should include the report from Apple in your email.
Hi Colin:
I already sent a message to milkmangames. As soon as I get a reply and a solution to this I will let you know. Thank´s for your advice.
He usually responds quickly, hope you hear soon.
Hi Colin:
I didn´t get a response from Milkmangames but I found something Stack Overflow that goes with what you said. I used this:
<string>Some ad content may access calendar</string>
and my app already went up on iTunesconnect.
Thanks again for your help.
Nice find! It even sounds plausible!
