Beim Profil "Iso Coated v2 300 ECI" wird die Schrift in CMYK wiedergegeben
Jun 28, 2017 Jun 28, 2017
Wenn ich in InDesign ein PDF mit dem Profil "Iso Coated v2 300 ECI" exportiere, wird die Schrift in CMYK wiedergegeben anstatt nur in Schwarz. Wer kann mir helfen? Letztes Jahr ging es noch. Habe mir auch schon InDesign 2015 runtergeladen, um zu prüfen, ob es an der 2017 Version liegt... Tut es aber leider nicht.
3.5K
Community Expert , Jun 28, 2017 Jun 28, 2017
I can remember also, that I've ever used "Keep values". So there is no other solution do you mean?
In the Export dialog there is an option to protect InDesign native colors this does not apply to placed objects. But you still want your document's assigned profile to be Iso Coated:
Make sure the document's assigned profile is ISO coated v2 300 ECI.
Edit>Assign Profiles (not Edit>Color Settings)
If the assigned profile is correct, then make sure it is also the Simulation Profile in Output Preview when you check the values in AcrobatPro
I did so. And also the printing company hasn't find any solution ... thank you for your answer!
Can you share the problem PDF?
How? I am only able to insert images...
Either a service like DropBox or your Adobe CC account lets you share files.
From you Creative Cloud App choose assets. Open folder will open the creative cloud folder with assets that get sync'd to the cloud. If you add files to that folder then choose View on Web there will be an option to share selected files
https://www.dropbox.com/s/1zxl4xvs4cxyrfv/ISOcoated_v2_300_eci.pdf?dl=0
This file has the same problem... Thank you for the effort!
exported this document with „Iso Coated v2 300% ECI“. I‘ve got the profil from the printing company and last year I didn‘t have any problem with this profil. Now the fonts are in CMYK instead only in black. If I try it with FOGRA 39, there isn‘t any problem with the fonts. Very strange...
Can you show us the problem document's Assigned Profiles... dialog. It needs to be this:
Bei den Farbmanagementeinstellungen, Richtlinien CMYK muss stehen, Werte beibehalten, ansonsten kommt es zu einer CMYK-Lab-CMYK-Konvertierung, die in 4c-Schwarzwerten resultiert.
Zudem erfordert diese Einstellung, dass Du für den Druck Farbbilder in RGB und nicht in CMYK platzierst und erst bei der Ausgabe, und nicht in Photoshop, die Bilder in das Zielprofil konvertierst.
Diese Variante hatte ich auch mit Erfolg ausprobiert, wobei mich davon abgehalten hat, dass da steht "Farbige Objekte ohne eingebettete Profile werden nicht konvertiert".
Ich finde es schwierig RGB-Bilder zu benutzen und sich dann vom Ergebnis im PDF überraschen zu lassen.
Ich kann mich auch nicht daran erinnern, dass ich jemals "Werte beibehalten" benutzt habe. Es gibt also keine andere Lösung meinst Du?
