Hello,
I have an SVG file that has quite a few objects on it. I need to change all the stroke color to grey and the strokewidth to .2.
When I attempt to use a loop, the process works, but it takes 9 minutes to process a file. I have to do it faster.
//this shows construct for updating color with a loop.
for ( i = 0; i <doc.pathItems.length; i++ ) {
pathArt = doc.pathItems;
pathArt.strokeColor = myNewColor;
Another post about a similar situation recommended using the approach of selecting items with executeMenuCommand and then changing the default fill color.
[Scripting] I need to implement a script to change 100,000 pathItems color in 1 time
I have the following script which selects all items, but does not actually change the default fill color or the stroke weight.:
app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
var doc = app.activeDocument;
//doc.DefaultStrokeColor = makeColor(153,153,153);
app.executeMenuCommand("selectall");
doc.DefaultStrokeWidth = .2;
function makeColor(r,g,b){
var c = new RGBColor();
c.red = r;
c.green = g;
c.blue = b;
return c;
How can I perform the change of stroke color and stroke weight without a loop?
Thanks so much for your time.
Maybe because it's supposed to be lowercase 'd' and not 'D'.
Oh man - thanks so much! I cant believe I didnt catch that! Thanks so much!
