Renaming Sub-Layer
Advisor ,
Jun 28, 2017 Jun 28, 2017
I have this tiny script to rename a Sub-layer which works the first time I use it, then it adds to the existing sub-layer name when I run it after the first time.
var docRef = activeDocument;
var sel = docRef.selection;
for (var i=0; i < sel.length; i++)
     sel.name = "CUTTER_B" + sel.name;
Any way to get this to consistently rename the sub-layer?
Scripting
409
Adobe
Hi PrepressPro1
your code only works with page items - not with sublayers.
Unfortunately you didn't answer one month ago.
select by layer name
"… is this "sublayer" really a sublayer? Or a grouped item instead? …"
Same question again.
For selected page items you can do something like this
for (var i=0; i < sel.length; i++) {
    var nme = sel.name.replace("CUTTER_B","");
    sel.name = "CUTTER_B" + nme;
Have fun
Advisor ,
It is an object on a sub-layer. Sorry for the hiatus in my posting. Projects get back burnered with the press of production work.  Thank you for your reply.
Advisor ,
Here is the sub-layer before running the scrip with the object selected.
After the script is run.
It still adds the name instead of replacing the name.
That makes no difference. Same procedere as for page items
var sel = docRef.activeLayer;
//var sel = docRef.selection;
//for (var i=0; i < sel.length; i++) {
    //var nme = sel.name.replace("CUTTER_B","");
    //sel.name = "CUTTER_B" + nme;
Have fun
Or if I understood you wrong: Would you replace the whole name with Cutter_B?
Then: sel.name = "CUTTER_B"
