Dear community,
I have been working on a project for quite some time now. Finally, the *.fla animation looks ready and I'd like to share it with my colleagues, but the exported MP4 file does not update to the current version of the *.fla animation. I have tried to save it under a new name, debug it, etc but nothing helped!
What can I do if there stay fragments of an old version of the animation behind?
The files can be downloaded from the following link: https://filestation.metrohm.com:7001/sharing/l2gHUkDer The problematic scene starts at 1 min.
Thank you all for your help!
Best regards,
Iris
Adobe Animate CC Version 2015.1 Build 15.1.0.210
Ok so as far as I can tell the problem is that you have duplicated the animation of the yellow ball. It has been animated once in 'Austauch.swf' and then again inside the movieclip 'Greenball'
This explains why the animation looks correct within Animate but incorrect once exported.
Delete all the animation within the 'Greenball' movie clip and this should fix your problem.
Please let me know if you have any questions
Cant download the file...
The link was a small challenge. The files are big, I'll look at them and report back.
On the Control menu is an option Clear Publish Cache. Try that to see if it solves the problem.
Also, if you're creating this for video you would want to set all of the bitmaps in the library to Allow Smoothing and Lossless. You can select all of the bitmaps in one go, use the i button in the library to show Properties, and select allow smoothing and lossless. They will all get changed at once.
If you're still seeing a problem, tell me a timecode for when it looks wrong, then I can look at that exact point in the animation.
I made a version, which has all the bitmaps set to lossless. See if my one looks correct (other than I don't have the right font):
http://colin.scienceninja.com/CationSuppressor.mp4
The file is still uploading, but you can use the link to see the start. It should be fully uploaded in about 15 minutes.
The problem appears to be that the yellow balls do not stick to the larger balls instead they scatter and pop in and out of the screen from 1:00 onwards. Having a look at the file now I have no idea why this is happening, I'll investigate some more.
Thank you so much! This helped me a lot! As I am a newbie to the Animation Business, this is one part where I did get lost, apparently.
