Hi I don't know why I'm not able to draw on InDesign. I just need to make a simple line, but everytime I try to make one, I can't get it to show. I used to be able to do it but now it doesn't seem to work. I've tried with the pen, the pencil and the line tool, with different strokes (and color) but it's like it's invisible. I can select the path, but I cannot see it, and I have no idea how to fix it.
____________
Hola! No sé por qué no puedo dibujar en InDesign
Necesito hacer una lÃnea básica, pero cada vez que intento hacerla, no logro que se vea. Antes podÃa hacerlo pero ahora no me funciona. He tratado con la pluma, el lápiz y la herramienta de lÃnea, con diferentes grosores (y color) pero es como si fuera invisible. Puedo seleccionar el trazo, pero no puedo verlo y no tengo idea cómo arreglarlo.
Please help!
You say you've tried it with different strokes and colours, but have you checked the stroke weight? A width of 0pt won't show up:
Did you set the stroke to something other than none or zero points?
Justin (and Bob) are correct.
But since you have been trying—seemingly without success—you may have a dozen or so invisible lines that you will want to delete! Spin open your Layers panel and select and delete them.)
