How can I change the shortcut for Select and Mask... from bringing up the old "Refine Edges" tool to taking me to Select and Mask? No matter how I change the shortcut, the only way I can bring up Select and Mask... is by clicking on the button. I MUCH prefer using a shortcut.
Alt+Ctrl+R brings up select and mask here (Windows 10 and CC2017.1.1)
Dave
So sorry, I should have mentioned I am a MacOS user. Cmd+Shift+R brings up "refine edges" not Select and Mask in CC2017.0.1 for MacOS.
Hi
For Mac Select & Mask should be Cmd+Opt+R
Learn how to use the dedicated Select And Mask workspace in Photoshop CC.
Dave
No go, unfortunately, no matter which shortcut I use or change it to, it still goes to "Refine Edges"
If I click and drag down to the menu, I do get "Select and Mask", but even if I use Quickeys to do a menu selection, it still gives me "Refine Edges"
Are you using CC 2017? Cuase command alt R goes to Select & Mask
Well, yes and no.
In the meantime, I upgraded to CC2017.1.1
Not sure how that affects this, BUT.
CMD+OPT+R did not take me to Select and Mask, as I had previously changed Select and Mask to cmd+shift+R, which still took me to Refine Edges.
When creating shortcuts with "Keyboards Shortcuts & Menus..." NO combination of shortcuts will take you to Select and Mask EXCEPT CMD+OPT+R! All other combos send you to Refine Edges. To get to Select and Mask via the keyboard, you MUST set your shortcut to CMD+OPT+R. I would hope someone confirms this by trying.
This may be a bug.
OTOH, my problem is sorta fixed. Now I have to use Quickeys to allow me to use my preferred keyboard combo.
UPDATE:
Nope, CMD+Shift+R is so ingrained as Refine Edges, even using Alias Keystrokes in Quickeys does not work. Again CMD+OPT+R must be used exclusively.
