Hello,
It appears there's a render/playback issue when using Digital Juice Jumpbacks with the latest update to Ae. I recently worked on a project that used a Jumpback and it would have taken 25 hours to render when previous renders on earlier versions of Ae only took 19 minutes. The work around I used was importing the the Jumpback into another editing program, export out as a .mov file and re-import into Ae. This has happened it the past but was corrected, will it be corrected on the next update?
Thank you.
There's nothing unique about Jumpbacks as far as I know. What format and codec are the ones you're having trouble with?
Also, double-check that your composition hasn't inadvertently been set to use the ray-traced renderer.
Hi JeramiahK,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
