Hello! Any help would be so greatly appreciated! I was running some batch edits and photoshop stopped responding. Ever since I've started it back up, photos at 100% zoom are showing much smaller than they were before. Opening the same images (2400x1600) take up close to the whole screen in any other program when I click "show actual size" but in photoshop it shows very small at 100% zoom - it takes setting to 200% to take up the whole screen, which blurs the image. I attached some screen shots of the same image open at 100% in Photoshop and 100% in Preview. I'm very aware of the existing never-ending thread about this topic from 2013ish, but have been using Photoshop CC on my retina imac for months and have not had this issue until just now. Photoshop was not set to "Open in low resolution" before, so just not sure what changed to make it this way all of a sudden. Any idea what the problem could be? THANK YOU!
Could be a corrupt preferences file. That what I think when something goes wrong with Photoshop and you know you did not adjust it. Try a reset.
Thank you for the suggestion, but still the same after reset.
Let's look at your system info. Go to Help > System Info and click on the Copy button in the dialog. Paste the results in your reply.
Sorry, having an issues replying directly. Here is what I got:
Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967 x64
Number of Launches: 1
Operating System: Mac OS 10.12.5
System architecture: Intel CPU Family:6, Model:94, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 3200 MHz
Built-in memory: 40960 MB
Free memory: 24795 MB
Memory available to Photoshop: 38132 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=1440, right=2560
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="AMD Radeon R9 M380 OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="AMD Radeon R9 M380 OpenGL Engine"
glgpu[0].GLRendererID=16915460
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Apr 4 2017 19:07:42)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="AMD Radeon R9 M380 Compute Engine"
clgpu[0].CLVendor="AMD"
clgpu[0].CLVendorID=16915456
clgpu[0].CLDriverVersion="1.2 (Apr 27 2017 22:10:57)"
clgpu[0].CLBandwidth=6.23009e+10
clgpu[0].CLCompute=646.634
nativegpu[0].NativeName="AMD Radeon R9 M380"
License Type: Subscription
Serial number: 96040852918536528966
GUIDBucket:
bucket: 6
test: control
Application folder: /Applications/Adobe Photoshop CC 2017/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 930.7G, 406.2G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-ins/
Installed components:
AdbePM.framework AdbePM 2.5.00.377243 1.578146
adobe_caps.framework adobe_caps 10.0.0.6 1.584361
AdobeACE.framework AdobeACE 2.20.02.37848 79.579975
AdobeAGM.framework AdobeAGM 4.30.87.37848 79.579975
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.34320 79.562390
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.34320 79.562390
AdobeBIB.framework AdobeBIB 1.2.03.37848 79.579975
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 79.579975
AdobeCoolType.framework AdobeCoolType 5.15.00.37848 79.579975
AdobeCrashReporter.framework AdobeCrashReporter 7.3.2
AdobeExtendScript.framework AdobeExtendScript 4.5.6.5 80.1089815
AdobeJP2K.framework AdobeJP2K 1.2.2.38234 79.266006
AdobeLinguistic.framework 22175
AdobeMPS.framework AdobeMPS 5.8.1.37174 79.577269
AdobeOwl.framework AdobeOwl 5.2.11
AdobePDFL.framework AdobePDFL 15.0.0.36975 79.195992
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 7.4.1.60.45263
AdobeScCore.framework AdobeScCore 4.5.6.5 80.1089815
AdobeSVGAGM.framework AdobeSVGAGM 1.0.0.37848 79.579975
AdobeSVGRE.framework AdobeSVGRE 6.0 79.579975
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 79.159824 79.159824
AdobeXMPFiles.framework AdobeXMPFiles 79.159824 79.159824
AdobeXMPScript.framework AdobeXMPScript 79.159824 79.159824
ahclient.framework ahclient 2.2.0.1
AIDE.framework AIDE 1.5.0.36540 79.574279
aif.framework aif 6.0.00.1 1.
amtlib.framework amtlib 10.0.0.119
boost_date_time.framework boost_date_time 10.0.0.0
boost_filesystem.framework boost_filesystem 10.0.0.0
boost_signals.framework boost_signals 10.0.0.0
boost_system.framework boost_system 10.0.0.0
boost_threads.framework boost_threads 10.0.0.0
Cg.framework NVIDIA Cg
CITThreading.framework
dvaaudiodevice.framework dvaaudiodevice 10.0.0.0
dvacore.framework dvacore 10.0.0.0
dvamarshal.framework dvamarshal 10.0.0.0
dvamediatypes.framework dvamediatypes 10.0.0.0
dvametadata.framework dvametadata 10.0.0.0
dvametadataapi.framework dvametadataapi 10.0.0.0
dvametadataUI.framework dvametadataUI 10.0.0.0
dvaplayer.framework dvaplayer 10.0.0.0
dvatransport.framework dvatransport 10.0.0.0
dvaui.framework dvaui 10.0.0.0
dvaunittesting.framework dvaunittesting 10.0.0.0
dynamiclink.framework dynamiclink 10.0.0.0
ICUConverter.framework ICUConverter 3.61 "gtlib_6.0" "." "21287"
ICUData.framework ICUData 3.61 "gtlib_6.0" "." "21287"
ICUUnicode.framework ICUUnicode 3.61 "gtlib_6.0" "." "21287"
LogSession.framework LogSession 7.4.1.60.45263
manta.framework manta 2.0.00.1 1.
mediacoreif.framework mediacoreif 10.0.0.0
PlugPlugExternalObject.framework 7.0.0.67
PlugPlugOwl.framework PlugPlugOwl 7.0.0.67
UpdaterNotifications.framework UpdaterNotifications 10.0.0.1 "10.0.0.1"
WRServices.framework
Required plug-ins:
3D Studio 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 18.1.1, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 18.1.1 ©1993-2017 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 9.10.1 (750), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 9.10.1 (750), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 18.1.1 ©2002-2017 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 18.1.1 ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 18.1.1 Copyright © 2003-2017 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 18.1.1 ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 18.1.1 Copyright © 2007-2017 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Entropy 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Export Color Lookup Tables 18.1.1 Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Extrude 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 18.1.1 ©1990-2017 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
HSB/HSL 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IFF Format 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IGES 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Ink Outlines 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 18.1.1 Copyright © 2001-2017 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 18.1.1, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 18.1.1, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 18.1.1, Copyright © 2001-2017 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 18.1.1 ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 18.1.1 Copyright © 1993-2017 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 18.1.1 ©1990-2017 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 18.1.1 Copyright © 1990-2017 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 18.1.1 ©1993-2017 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
OpenEXR 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 18.1.1 ©1989-2017 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Photoshop Touch Copyright ©2013-2017 Adobe Systems Incorporated - from the file “PSDX.plugin”
Picture Package Filter 18.1.1 ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 18.1.1 ©1989-2017 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PLY 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
PNG 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 18.1.1 ©1989-2017 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PRC 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Radial Blur 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 18.1.1 ©2003-2017 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Render Color Lookup Grid 18.1.1 Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Reticulation 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 18.1.1, Copyright © 1999-2017 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 18.1.1, Copyright © 2017 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shake Reduction 18.1.1, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
Shear 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 18.1.1 Copyright © 1993-2017 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spaces 18.1.1, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
Spatter 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
STL 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Sumi-e 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Topaz Adjust 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “TopazAdjust5.plugin”
Torn Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
Virtual Reality Modeling Language | VRML 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Water Paper 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 18.1.1 ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 18.1.1 ©1989-2017 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/purchase.html”
Recent Files 1.4.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_1_4_2_009/index.html”
Libraries 2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/index.html”
New Document 1.4.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_1_4_2_009/fnft.html”
Start 1.4.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_1_4_2_009/index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
Adobe Color Themes 6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
Export As 3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
Device Preview 1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
com.adobe.preview.loader 1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
Installed TWAIN devices: NONE
Thanks for the System Info. This is a tough problem. I do not see anything in System Info that looks off. You are running the latest updates.
Your display is bottom=1440, right=2560 and that's close to the size of your image.
For experimentation purposes, can you switch to another user account or create a new user account and see if you note the same behavior with your file?
I want to be sure it is not something such as an extension or plugin that went bad.
I created a new user account, signed in and it's behaving the same...
Next idea is not just a simple uninstall (which leaves behind support and configuration files), but a clean uninstall.
Uninstall and then run the Cleaner Tool Use the Creative Cloud Cleaner Tool to solve installation problems
Then reinstall.
You are also entitled to install and run an earlier version: CC 2015.5 as an example. I keep an earlier version around in case 2017 runs into difficulties. That way my work doesn't get put on hold.
Gene
Posting downsampled screenshots is not a good idea.
Just to make sure: That is 2400px x 1600px?
What have you done for trouble-shooting so far?
Restoring Preferences after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved might be a good starting point:
https://helpx.adobe.com/photoshop/kb/basic-trouble-shooting-steps.html
