I'm using the Core Start and Core End points to move this solid frame-by-frame over a video, and it was working fine, though I did something, not sure what, and now it seems to be doing something to transform the solid/shape on some of the frames (please see attached), sometimes when I drag on one of the Core Start or end points it is widening the rectangle. I want the shape to be a rectangle and not change. I only want to move the Core points to match the footage. In the attached image you can see the shape becomes wider at the top. What did I do, and how can I change the shape back on each frame as necessary to the way I like? Thank you in advance!
Thanks.
Disable the "Perspective" Option, check that the start and end widths are identical and also turn off motion blur.
Mylenium
What is a "core start" & "core end" point?
Hi southwestform,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
