Ok, I'm going to try listing all I know and hopefully someone will help me! I've updated the driver to what windows says is the most recent, but I don't think it's listed on the drivers that support photoshop list. It's Intel HD Graphics 3000. I'm using windows 10. I have no idea if the laptop supports OpenGL drawing. The laptop is an Asus K53E series. I'm not sure what else I need to tell anybody. Could someone please help? I literally have no idea about computers. I've spent the last 2 hours on google trying to find an answer but I keep going round in circles. Thank you 😃
Your machine's hardware is at the very bottom of what is required to run Photoshop. 4GB of memory with Windows 10 is barely sufficient to run graphics software from Adobe, I am afraid.
Integrated Intel HD graphic chips (such as the HD 3000 you have) share the same memory as the CPU, which results in in having even less available memory left for Photoshop. But more importantly, Intel graphic chips are barely capable to provide sufficient OpenGL speed for most 3d applications. IF it works, it will
...Copy link to clipboard
Hi
Please go to Photoshop Help >System Info click "Copy" and paste the info into a post here.
Dave
Adobe Photoshop Version: 20.0.0 20180920.r.24 2018/09/20: 1193433 x64
Number of Launches: 72
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.15063.296
System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2 MHz
Built-in memory: 3990 MB
Free memory: 2539 MB
Memory available to Photoshop: 3628 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=768, right=1024
OpenGL Drawing: Disabled.
OpenGL Allow Old GPUs: Not Detected.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="3.1"
glgpu[0].IsIntegratedGLGPU=1
glgpu[0].GLMemoryMB=1803
glgpu[0].GLName="Intel(R) HD Graphics 3000"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="9.17.10.4459"
glgpu[0].GLRectTextureSize=8192
glgpu[0].GLRenderer="Intel(R) HD Graphics 3000"
glgpu[0].GLRendererID=278
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32"
glgpu[0].GLDriverDate="20160519000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Intel Build 9.17.10.4459"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[512]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[41]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
License Type: Unknown
Serial number: XXXX-XXXX-XXXX-XXXX-XXXX
GUIDBucket:Composite Core (enable_composite_core): onComposite Core UI (comp_core_ui): offDocument Graph (enable_doc_graph): off
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\
Temporary file path: C:\Users\Dell\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 147.2G, 19.2G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\Plug-Ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2018/09/06-18:53:59 79.601691 79.601691
AdbePM.dll PatchMatch 2018/09/10:19:04:15 1.601805 1.601805
AdobeLinguistic.dll Adobe Linguisitc Library 13.0.0.0
AdobeOwl.dll Adobe Owl 5.3.0
AdobePDFL.dll PDFL 2018/08/23-00:56:13 79.301181 79.301181
AdobePIP.dll Adobe Product Improvement Program 8.0.0.41.47939
AdobeSVGAGM.dll AdobeSVGAGM 79.600623 79.600623
AdobeXMP.dll Adobe XMP Core 2018/08/13-16:40:22 79.163499 79.163499
AdobeXMPFiles.dll Adobe XMP Files 2018/08/13-16:40:22 79.163499 79.163499
AdobeXMPScript.dll Adobe XMP Script 2018/08/13-16:40:22 79.163499 79.163499
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2018/08/14-01:11:25 79.600623 79.600623
ahclient.dll AdobeHelp Dynamic Link Library 4.0.0.0
AIDE.dll AIDE 2018/08/10-16:31:38 79.600470 79.600470
ARE.dll ARE 2018/08/14-01:11:25 79.600623 79.600623
AXE8SharedExpat.dll AXE8SharedExpat 2018/06/25-18:00:38 79.598424 79.598424
AXEDOMCore.dll AXEDOMCore 2018/06/25-18:00:38 79.598424 79.598424
Bib.dll BIB 2018/08/14-01:11:25 79.600623 79.600623
BIBUtils.dll BIBUtils 2018/08/14-01:11:25 79.600623 79.600623
boost_date_time.dll photoshopdva 12.1.0
boost_filesystem.dll photoshopdva 12.1.0
boost_system.dll photoshopdva 12.1.0
boost_threads.dll photoshopdva 12.1.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2018/08/14-01:11:25 79.600623 79.600623
CRClient.dll Adobe Crash Reporter Client DLL 2.0.3.0
dnssd.dll Bonjour 3,0,0,2
dvaaccelerate.dll photoshopdva 12.1.0
dvaappsupport.dll photoshopdva 12.1.0
dvaaudiodevice.dll photoshopdva 12.1.0
dvacore.dll photoshopdva 12.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 12.1.0
dvamediatypes.dll photoshopdva 12.1.0
dvametadata.dll photoshopdva 12.1.0
dvametadataapi.dll photoshopdva 12.1.0
dvametadataui.dll photoshopdva 12.1.0
dvaplayer.dll photoshopdva 12.1.0
dvascripting.dll photoshopdva 12.1.0
dvatransport.dll photoshopdva 12.1.0
dvaui.dll photoshopdva 12.1.0
dvaunittesting.dll photoshopdva 12.1.0
dynamiclink.dll photoshopdva 12.1.0
ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1157194 81.1157194
icucnv58.dll International Components for Unicode 58, 2, 0, 0
icudt58.dll International Components for Unicode 58, 2, 0, 0
icuuc58.dll International Components for Unicode 58, 2, 0, 0
igestep30.dll IGES Reader 9.3.0.113
JP2KLib.dll JP2KLib 2018/06/25-18:00:38 79.271024 79.271024
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler 18.0.0
LogSession.dll LogSession 8.0.0.41.47939
mediacoreif.dll photoshopdva 12.1.0
MPS.dll MPS 2018/08/06-15:20:35 79.600183 79.600183
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2019 20.0
Plugin.dll Adobe Photoshop CC 2019 20.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 9.2.1
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 9.2.1.39
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2019 20.0
SCCore.dll ScCore 2017/08/31-12:13:14 81.1157194 81.1157194
SVGRE.dll SVGRE 79.600623 79.600623
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 18.0.0
tbb.dll Intel(R) Threading Building Blocks for Windows 2018, 0, 2017, 1205
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2018, 0, 2017, 1205
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WinRTSupport.dll Adobe Photoshop Windows RT Support 20.0.0.0
WRServices.dll WRServices Tue August 14 2018 12:26:24 Build 0.23627 0.23627
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Accented Edges 20.0 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 20.0 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 20.0 - from the file “Filter Gallery.8bf”
Average 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Average.8bf”
Bas Relief 20.0 - from the file “Filter Gallery.8bf”
BMP 20.0 - from the file “Standard MultiPlugin.8bf”
Camera Raw 10.0 - from the file “Camera Raw.8bi”
Camera Raw Filter 10.0 - from the file “Camera Raw.8bi”
Chalk && Charcoal 20.0 - from the file “Filter Gallery.8bf”
Chrome 20.0 - from the file “Filter Gallery.8bf”
Cineon 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Cineon.8bi”
Clouds 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Clouds.8bf”
Collada 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Color Halftone 20.0 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 20.0 - from the file “Filter Gallery.8bf”
Conté Crayon 20.0 - from the file “Filter Gallery.8bf”
Craquelure 20.0 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 20.0 - from the file “Standard MultiPlugin.8bf”
Crosshatch 20.0 - from the file “Filter Gallery.8bf”
Crystallize 20.0 - from the file “Standard MultiPlugin.8bf”
Cutout 20.0 - from the file “Filter Gallery.8bf”
Dark Strokes 20.0 - from the file “Filter Gallery.8bf”
De-Interlace 20.0 - from the file “Standard MultiPlugin.8bf”
Dicom 20.0 - from the file “Dicom.8bi”
Difference Clouds 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Clouds.8bf”
Diffuse Glow 20.0 - from the file “Filter Gallery.8bf”
Displace 20.0 - from the file “Standard MultiPlugin.8bf”
Dry Brush 20.0 - from the file “Filter Gallery.8bf”
Eazel Acquire 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “EazelAcquire.8ba”
Entropy 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Export Color Lookup Tables 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Export3DLUT.8be”
Extrude 20.0 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “FastCore.8bx”
Fibers 20.0 - from the file “Standard MultiPlugin.8bf”
Film Grain 20.0 - from the file “Filter Gallery.8bf”
Filter Gallery 20.0 - from the file “Filter Gallery.8bf”
Flash 3D 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Fresco 20.0 - from the file “Filter Gallery.8bf”
Glass 20.0 - from the file “Filter Gallery.8bf”
Glowing Edges 20.0 - from the file “Filter Gallery.8bf”
Google Earth 4 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Graphic Pen 20.0 - from the file “Filter Gallery.8bf”
Halftone Pattern 20.0 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 20.0 - from the file “HDRMergeUI.8bf”
HSB/HSL 20.0 - from the file “Standard MultiPlugin.8bf”
IFF Format 20.0 - from the file “Standard MultiPlugin.8bf”
IGES 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Ink Outlines 20.0 - from the file “Filter Gallery.8bf”
JPEG 2000 20.0 - from the file “JPEG2000.8bi”
Kurtosis 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Lens Blur 20.0 - from the file “Lens Blur.8bf”
Lens Correction 20.0 - from the file “Lens Correction.8bf”
Lens Flare 20.0 - from the file “Standard MultiPlugin.8bf”
Liquify 20.0 - from the file “Liquify.8bf”
Matlab Operation 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “ChannelPort.8bf”
Maximum 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Mean 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Measurement Core 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “MeasurementCore.8me”
Median 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Mezzotint 20.0 - from the file “Standard MultiPlugin.8bf”
Minimum 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
MMXCore Routines 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “MMXCore.8bx”
Mosaic Tiles 20.0 - from the file “Filter Gallery.8bf”
Multiprocessor Support 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “MultiProcessor Support.8bx”
Neon Glow 20.0 - from the file “Filter Gallery.8bf”
Note Paper 20.0 - from the file “Filter Gallery.8bf”
NTSC Colors 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “NTSC Colors.8bf”
Ocean Ripple 20.0 - from the file “Filter Gallery.8bf”
OpenEXR 20.0 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 20.0 - from the file “Filter Gallery.8bf”
Palette Knife 20.0 - from the file “Filter Gallery.8bf”
Patchwork 20.0 - from the file “Filter Gallery.8bf”
Paths to Illustrator 20.0 - from the file “Standard MultiPlugin.8bf”
PCX 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “PCX.8bi”
Photocopy 20.0 - from the file “Filter Gallery.8bf”
Picture Package Filter 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “ChannelPort.8bf”
Pinch 20.0 - from the file “Standard MultiPlugin.8bf”
Pixar 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Pixar.8bi”
Plaster 20.0 - from the file “Filter Gallery.8bf”
Plastic Wrap 20.0 - from the file “Filter Gallery.8bf”
PLY 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Pointillize 20.0 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 20.0 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “PBM.8bi”
Poster Edges 20.0 - from the file “Filter Gallery.8bf”
PRC 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Radial Blur 20.0 - from the file “Standard MultiPlugin.8bf”
Radiance 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Radiance.8bi”
Range 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Render Color Lookup Grid 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Export3DLUT.8be”
Reticulation 20.0 - from the file “Filter Gallery.8bf”
Ripple 20.0 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 20.0 - from the file “Filter Gallery.8bf”
Save for Web 20.0 - from the file “Save for Web.8be”
ScriptingSupport 20.0 - from the file “ScriptingSupport.8li”
Shake Reduction 20.0 - from the file “Shake Reduction.8bf”
Shear 20.0 - from the file “Standard MultiPlugin.8bf”
Skewness 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Smart Blur 20.0 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 20.0 - from the file “Filter Gallery.8bf”
Solarize 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “Solarize.8bf”
Spaces 20.0 - from the file “Spaces.8li”
Spatter 20.0 - from the file “Filter Gallery.8bf”
Spherize 20.0 - from the file “Standard MultiPlugin.8bf”
Sponge 20.0 - from the file “Filter Gallery.8bf”
Sprayed Strokes 20.0 - from the file “Filter Gallery.8bf”
Stained Glass 20.0 - from the file “Filter Gallery.8bf”
Stamp 20.0 - from the file “Filter Gallery.8bf”
Standard Deviation 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
STL 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Sumi-e 20.0 - from the file “Filter Gallery.8bf”
Summation 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Targa 20.0 - from the file “Standard MultiPlugin.8bf”
Texturizer 20.0 - from the file “Filter Gallery.8bf”
Tiles 20.0 - from the file “Standard MultiPlugin.8bf”
Torn Edges 20.0 - from the file “Filter Gallery.8bf”
Twirl 20.0 - from the file “Standard MultiPlugin.8bf”
U3D 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Underpainting 20.0 - from the file “Filter Gallery.8bf”
Vanishing Point 20.0 - from the file “VanishingPoint.8bf”
Variance 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
Water Paper 20.0 - from the file “Filter Gallery.8bf”
Watercolor 20.0 - from the file “Filter Gallery.8bf”
Wave 20.0 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “U3D.8bi”
WIA Support 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “WIASupport.8li”
Wind 20.0 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 20.0 (20181029.r.41 2018/010/29: 1197484) - from the file “WBMP.8bi”
ZigZag 20.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.Butler.backend 2.1.1 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
com.adobe.inapp.purchase 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_2_108\purchaseStock.html”
com.adobe.stock.panel.licensing 0.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.stock.panel.licensing\index.html”
Libraries 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_2_108\index.html”
New Document 2.5.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.5.1\fnft.html?v=2.5.1.8”
com.adobe.inapp.typekit.purchase 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_2_108\purchaseTypekit.html”
Home 2.7.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.7.1\index.html?v=2.7.1.2”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 4.6.3 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.photoshop.crema\index.html”
Installed TWAIN devices: NONE
Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967 x64
Number of Launches: 4
System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
Physical processor count: 2
Logical processor count: 4
Processor speed: 2095 MHz
Built-in memory: 3874 MB
Free memory: 1842 MB
Memory available to Photoshop: 3080 MB
History Thumbnails: Enabled.
Touch Bar: Enabled.
Highbeam: Enabled.
Image tile size: 128K
TextComposer: Latin
OpenCL crashed on 6/29/2017 at 12:02:20 PM (Initializing Shared Sampling OpenCL feature)
Display: 1
Display Bounds: top=0, left=0, bottom=768, right=1366
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=1873
License Type: Subscription
Serial number: 96040130182841800109
GUIDBucket:
bucket: 113
test: ReduceUXFriction
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\jays\AppData\Local\Temp\
Scratch volume(s):
Startup, 238.0G, 92.7G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
ACE.dll ACE 2017/01/26-01:10:02 79.579975 79.579975
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.579975 79.579975
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
AGM.dll AGM 2017/01/26-01:10:02 79.579975 79.579975
ahclient.dll AdobeHelp Dynamic Link Library 2.2.0.1
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7) 1.000000
ARE.dll ARE 2017/01/26-01:10:02 79.579975 79.579975
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/01/26-01:10:02 79.579975 79.579975
BIBUtils.dll BIBUtils 2017/01/26-01:10:02 79.579975 79.579975
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
CoolType.dll CoolType 2017/01/26-01:10:02 79.579975 79.579975
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/12/13-13:10:33 80.1089815 80.1089815
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
imslib.dll IMSLib DLL 10.0.0.11
JP2KLib.dll JP2KLib 2017/04/05-14:24:38 79.266006 79.266006
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
Photoshop.dll Adobe Photoshop CC 2017 18.1.1
Plugin.dll Adobe Photoshop CC 2017 18.1.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.1.1
PSViews.dll Adobe Photoshop CC 2017 18.1.1
SCCore.dll ScCore 2016/12/13-13:10:33 80.1089815 80.1089815
SVGRE.dll SVGRE 79.579975 79.579975
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
Required plug-ins:
3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Accented Edges 18.1.1 - from the file “Filter Gallery”
Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle”
Angled Strokes 18.1.1 - from the file “Filter Gallery”
Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average”
Bas Relief 18.1.1 - from the file “Filter Gallery”
BMP 18.1.1 - from the file “Standard MultiPlugin”
Camera Raw 9.10.1 - from the file “Camera Raw”
Camera Raw Filter 9.10.1 - from the file “Camera Raw”
Chalk && Charcoal 18.1.1 - from the file “Filter Gallery”
Chrome 18.1.1 - from the file “Filter Gallery”
Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon”
Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Color Halftone 18.1.1 - from the file “Standard MultiPlugin”
Colored Pencil 18.1.1 - from the file “Filter Gallery”
CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin”
Conté Crayon 18.1.1 - from the file “Filter Gallery”
Craquelure 18.1.1 - from the file “Filter Gallery”
Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto”
Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin”
Crosshatch 18.1.1 - from the file “Filter Gallery”
Crystallize 18.1.1 - from the file “Standard MultiPlugin”
Cutout 18.1.1 - from the file “Filter Gallery”
Dark Strokes 18.1.1 - from the file “Filter Gallery”
De-Interlace 18.1.1 - from the file “Standard MultiPlugin”
Dicom 18.1.1 - from the file “Dicom”
Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
Diffuse Glow 18.1.1 - from the file “Filter Gallery”
Displace 18.1.1 - from the file “Standard MultiPlugin”
Dry Brush 18.1.1 - from the file “Filter Gallery”
Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire”
Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
Extrude 18.1.1 - from the file “Standard MultiPlugin”
FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore”
Fibers 18.1.1 - from the file “Standard MultiPlugin”
Film Grain 18.1.1 - from the file “Filter Gallery”
Filter Gallery 18.1.1 - from the file “Filter Gallery”
Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Fresco 18.1.1 - from the file “Filter Gallery”
Glass 18.1.1 - from the file “Filter Gallery”
Glowing Edges 18.1.1 - from the file “Filter Gallery”
Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Graphic Pen 18.1.1 - from the file “Filter Gallery”
Halftone Pattern 18.1.1 - from the file “Filter Gallery”
HDRMergeUI 18.1.1 - from the file “HDRMergeUI”
HSB/HSL 18.1.1 - from the file “Standard MultiPlugin”
IFF Format 18.1.1 - from the file “Standard MultiPlugin”
IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Ink Outlines 18.1.1 - from the file “Filter Gallery”
JPEG 2000 18.1.1 - from the file “JPEG2000”
Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Lens Blur 18.1.1 - from the file “Lens Blur”
Lens Correction 18.1.1 - from the file “Lens Correction”
Lens Flare 18.1.1 - from the file “Standard MultiPlugin”
Liquify 18.1.1 - from the file “Liquify”
Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Mezzotint 18.1.1 - from the file “Standard MultiPlugin”
Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore”
Mosaic Tiles 18.1.1 - from the file “Filter Gallery”
Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support”
Neon Glow 18.1.1 - from the file “Filter Gallery”
Note Paper 18.1.1 - from the file “Filter Gallery”
NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors”
Ocean Ripple 18.1.1 - from the file “Filter Gallery”
OpenEXR 18.1.1 - from the file “Standard MultiPlugin”
Paint Daubs 18.1.1 - from the file “Filter Gallery”
Palette Knife 18.1.1 - from the file “Filter Gallery”
Patchwork 18.1.1 - from the file “Filter Gallery”
Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin”
PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX”
Photocopy 18.1.1 - from the file “Filter Gallery”
Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine”
Photoshop Touch 14.0 - from the file “PSDX”
Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
Pinch 18.1.1 - from the file “Standard MultiPlugin”
Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar”
Plaster 18.1.1 - from the file “Filter Gallery”
Plastic Wrap 18.1.1 - from the file “Filter Gallery”
PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
PNG 18.1.1 - from the file “Standard MultiPlugin”
Pointillize 18.1.1 - from the file “Standard MultiPlugin”
Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin”
Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM”
Poster Edges 18.1.1 - from the file “Filter Gallery”
PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Radial Blur 18.1.1 - from the file “Standard MultiPlugin”
Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance”
Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
Reticulation 18.1.1 - from the file “Filter Gallery”
Ripple 18.1.1 - from the file “Standard MultiPlugin”
Rough Pastels 18.1.1 - from the file “Filter Gallery”
Save for Web 18.1.1 - from the file “Save for Web”
ScriptingSupport 18.1.1 - from the file “ScriptingSupport”
Shake Reduction 18.1.1 - from the file “Shake Reduction”
Shear 18.1.1 - from the file “Standard MultiPlugin”
Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Smart Blur 18.1.1 - from the file “Standard MultiPlugin”
Smudge Stick 18.1.1 - from the file “Filter Gallery”
Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize”
Spaces 18.1.1 - from the file “Spaces”
Spatter 18.1.1 - from the file “Filter Gallery”
Spherize 18.1.1 - from the file “Standard MultiPlugin”
Sponge 18.1.1 - from the file “Filter Gallery”
Sprayed Strokes 18.1.1 - from the file “Filter Gallery”
Stained Glass 18.1.1 - from the file “Filter Gallery”
Stamp 18.1.1 - from the file “Filter Gallery”
Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Sumi-e 18.1.1 - from the file “Filter Gallery”
Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Targa 18.1.1 - from the file “Standard MultiPlugin”
Texturizer 18.1.1 - from the file “Filter Gallery”
Tiles 18.1.1 - from the file “Standard MultiPlugin”
Torn Edges 18.1.1 - from the file “Filter Gallery”
Twirl 18.1.1 - from the file “Standard MultiPlugin”
U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Underpainting 18.1.1 - from the file “Filter Gallery”
Vanishing Point 18.1.1 - from the file “VanishingPoint”
Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Water Paper 18.1.1 - from the file “Filter Gallery”
Watercolor 18.1.1 - from the file “Filter Gallery”
Wave 18.1.1 - from the file “Standard MultiPlugin”
Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport”
Wind 18.1.1 - from the file “Standard MultiPlugin”
Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP”
ZigZag 18.1.1 - from the file “Standard MultiPlugin”
Extensions:
com.adobe.inapp.purchase 2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
New Document 2.0.0 - from the file “C:\Users\jays\AppData\Roaming\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_0_0_003\fnft.html”
Libraries 2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Start 2.0.0 - from the file “C:\Users\jays\AppData\Roaming\Adobe\CEP\extensions\CCX_START_EXTENSION_2_0_0_042\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Device Preview 1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Integrated Intel HD graphic chips (such as the HD 3000 you have) share the same memory as the CPU, which results in in having even less available memory left for Photoshop. But more importantly, Intel graphic chips are barely capable to provide sufficient OpenGL speed for most 3d applications. IF it works, it will be slow and cumbersome to work with.
In short, don't expect Photoshop's 3d acceleration to work well with Intel's integrated graphics with shared memory, if at all. If it does, expect glitches and sub-par performance.
Ah ok, thank you 😃
I ran into this here in 2021, as my work PC is also running Win10 on a Intel3000. I used this guide using Photoshop instead of Python in the guide, and it works fine 🙂
https://gist.github.com/rb-dahlb/26f316c5b6089807a139fc44ee69f0d1
Hi Amalie,
RAM memory?
