I like to print the current spread as two pages on my printer, just to have a simple paper output to look at. So, I hit Cmd-P, but I can't find out how to get the RHS printed. It is unclear how to tell ID to print both pages (how to define a range). E.g. the range says "A4 V:146" (must be an old name for the range from an import long ago, the format is actually Letter, not A4), I can try to turn it into A4 V:147, but I still get page 146 from the printer.
How can I quickly print a small range of pages directly from ID itself, without going through creating a full PDF first?
Select the spread(s) in the Pages panel and use the Pages panel menu to Print Spread
The Print dialog will be pre-filled, but check it:
On the General panel, check Spreads instead of Pages.
I already tried that of course, but it did not work
I'd suggest restoring your InDesign preferences:
Trash, Replace, Reset, or Restore the application Preferences
If that doesn't work, I'd try saving the file as an IDML and reopening and reprinting. The file could have become corrupted:
