Hello!
I'm looking for a solution, or a plugin, to get a quick access on my workspace to the workspace color settings. To switch CMYK profiles "on the fly" without clicking in the menus, etc. Here is a rough - and fake - image of what I have in mind:
Because I'm working with many clients and they all use different profiles. And I have to switch (to get the proof preview) several time by hour, for each project...
I think that I can do this with several scripts, one for each CMYK profiles. I can save and script several "proof profile" in the "proof setup" and call scripts via shortcuts or by clicking in the scripts panel.
But, I'm quite surprised that this is not a "native" panel/function or that there is no plugin about this...
Do you have some ideas about this? Suggestions?
To get the proof preview, assign a custom shortcut to View > Proof Setup. As long as the profile is installed, it can be accessed for proofing here, just as quickly and easily as your proposed panel.
There's no need to change the working space. If you submit CMYK the profile is much more easily set manually per document anyway, and if you submit RGB but just want to proof to CMYK, the working space is irrelevant.
Hello, I found a great extension to do this easily (by one click, an only only after configuration). Exactly what I was looking for:Configurator Reloaded Adobe Add-Ons EN - Configurator Reloaded – Photoshop Panel
