Hi all,
I have divided a single text frame into 15 columns. I need to move them around independently, so they need to be split from each other. How do I do that? Can somebody help me? I use Indesign CC, by the way.
I have tried using SplitStory script, but it only works in the case where different text frames are threaded together, not in this case.
Thank you.
I tried the script in the first link. The script for CS5 works fine in CC. The text frame is split into different threaded frames. After that I used Splitstory script to unlink them. The problem is solved!
Thank you so much.
