Heya there, everyone! I've been using Adobe Animate for a few years now, I love it, however I've had a question for awhile and I'm hoping I can get some help here.
I notice I get some severe frame drops when I have to motion tween anything movie symbol with filters added onto it, I usually go 24FPS and it'll be cut in half if I add some filters on a symbol. In this one instance I'm motion tweening some clouds across the sky so I have a glow and blur filter added on it but when they start to move it drops frames like crazy.
Any way to remedy this? Any and all help would be appreciate, I'm at my wit's end with this issue.
Thanks for anyone even reading!
-ConeZone
It does look very slow. With it being 1920z1080 and a glow and a blur filter, it might just not get that fast. But, if you're exporting to video the frame rate will be good.
If you are doing HTML5 Canvas, make sure to use Classic Tweens and not Motion Tweens. It will perform a lot better.
If you are doing ActionScript, and you mean that the frame rate is low when you do a Test Movie, then whatever you're doing is too demanding. But, it will export to video with perfect frame rate.
By the way, if it is HTML5 Canvas and you're using Classic Tweens, make sure not to do a custom ease. Don't click that pencil icon, just use the tween type and adjust the value between -100 and +100. A custom ease Classic Tween performs as badly as a Motion Tween.
Thank you so much for the response, Colin! I tried changing the tween to a classic instead of a motion without adjusting anything else and then changing it to adjusting the ease out/in and still no luck. The frames are dropping in the tween.
The clouds I'm moving are using blur, glow filter and the alpha is down about to 80%. So I'm not sure how to fix this issue, I always have the same issue if I try to zoom in on a scene, for example, and I have blur on for the background; it chugs like crazy. :< So no luck so far but I really appreciate the help!
Are you doing this to make a video? Could you put online an FLA that includes the slow part, so we could try it?
Oh, yes, I don't mind at all! I'm not sure how I would go about doing that, would I export the video in the file setting?
If you're only making this to be video (as opposed to playing in a browser), then you would use File/Export/Export Video, and no matter how complicated the animation is, the video will be perfect frame rate.
Oh, okay, I uploaded a clip of what I'm trying to do. I still think it looks kinda chuggy but I'll let you decide
https://www.youtube.com/watch?v=KRXMGHkuMWw&feature=youtu.be
Upon looking at my file, it was made in Actionscript 3, it's what I've been using for all my animations. And yeah, it's a video I animate cartoons and throw them up on Youtube
That plays smoothly. I really meant that you would give us the FLA that made the animation.
If things are just slow as you scrub around in the timeline, you could try using the View/Preview Mode options. Being set to Fast would work quicker than Full.
Oh! I see what you mean hahaha, my bad! I hope this works, this is the .fla file that I'm using to test out these clouds.
Direct link to the FLA file:
http://www.filehosting.org/file/details/677730/tsEabCgF6CSzSS2x/TESTclouds.fla
If you need to redownload the file.
http://www.filehosting.org/file/details/677730/TESTclouds.fla
I hope these links work, I'm not used to sending out FLA files haha! Thanks a lot, Colin, you are super helpful!
Ah, okay, thanks very much! Glad to see I wasn't going crazy haha, appreciate the help!
