Illustrator script.
Guest
Jul 04, 2017 Jul 04, 2017
here I have already retrieved nonNativeItems,below that JSON data is there, using this JSON data again how to re create the nonNativeItems in illustrator.
var page_details = {
"full_name": "C%3A%5CUsers%5CAdministrator%5CAppData%5CRoaming%5CSkype%5CMy%20Skype%20Received%20Files %5C324580-1.ai",
"name": "324580-1.ai",
"page_count": 1,
"height": 15.0098402235243,
"width": 10.3500027126736,
"top": 15.0098402235243,
"left": 0,
"modification_on": "2017-07-04 09:55:51",
"creation_on": "2017-07-04 09:55:36",
"pages": [{
  "page_number": 1,
  "left": 0,
  "heigth": 15.0098402235243
var selected_area = {
"arrSelectedArea": {
  "noe": 3,
  "xpos": 9.01471625434028,
  "ypos": 13.7328694661458,
  "height": 12.6598239474826,
  "width": 0.86028374565972,
  "pageNo": 1,
  "preview": "selectionareaexportimage1"
"arrCompoundPathItem": [
"arrImageFrames": [
"arrGraphItems": [
"arrLegacyTextItems": [
"arrMeshItems": [
"arrNonNativeItems": [{
  "xpos": 0,
  "ypos": 0.53643120659722,
  "styleJSON": "{\"controlBounds\":\"[648.0595703125,951.1435546875,712,949.1435546875]\",\"editable\":t rue,\"geometricBounds\":\"[649.0595703125,950.1435546875,711,950.1435546875]\",\"hidden\" : false,\"left\":649.0595703125,\"locked\":false,\"name\":\"\",\"opacity\":100,\"position\" : \"[649.0595703125,950.1435546875]\",\"sliced\":false,\"top\":950.1435546875,\"typename\": \ "NonNativeItem\",\"visibilityVariable\":null,\"visibleBounds\":\"[649.0595703125,950.1435 5 46875,711,950.1435546875]\",\"wrapInside\":\"\",\"wrapped\":false,\"wrapOffset\":\"\",\"a r r_position\":0}",
  "height": 0,
  "index": null,
  "layer": "Layer 1",
  "layer_info": "{\"name\":\"Layer 1\",\"layerName\":\"Layer 1\",\"typename\":\"Layer\",\"opacity\":100,\"visible\":true,\"dimPlacedImages\":false}",
  "groupName": "",
  "arr_position": 0
"arrPluginItems": [
"arrRasterItems": [
"arrShapes": [
"arrSymbolItems": [
"arrTextFrames": [
"arrTextElements": [
"arrGroups": [
Scripting
874
Adobe
People's Champ ,
Jul 05, 2017 Jul 05, 2017
What's your point exactly ?
Valorous Hero ,
This must be one small puzzle piece of a big riddle.
Guest
yes,but how do I re create non native item in illustrator using above Json data,if anybody known please do reply
Valorous Hero ,
Jul 06, 2017 Jul 06, 2017
I ask myself, What are Non-Native items? I'm not sure as to what constitutes a definite description of all conditions which a non-native item meets, however, I did notice that these mysterious artifacts do make themselves present when one does ever place and embed a file which contains a gradient mesh. Although the scripting collection "Document.nonNativeItems" has no "add" method, they can be actually created within the document through importing a pre-made file, or creating a temporary file with the script. I couldn't find another method for creating these besides using a recorded action which uses the Expand menu item. This action recording is better than some other ones because it records the parameters, which is how you can guarantee that a gradient mesh is going to be produced.
The attached snippet shows you how to create non-native items.
It uses this kind of action to play the Expand command.
#target illustrator
function test(){
  if(app.documents.length == 0){
    alert("You must open a document");
    return;
  app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS; // turn off the alert boxes Illustrator produces
  var dummyFile = File("C:\\Users\\You\\TryToMakeNonNative.ai"); // paste in your path to the temp file you'll be making
  var dummyDoc = app.documents.add(); // make the new document
  dummyDoc.pathItems.rectangle(0, 100, 200, -200); // add one rectangle path
  dummyDoc.pathItems[0].filled = false; // set the path to have no fill
  dummyDoc.pathItems[0].selected = true; // the path is now selected in Illustrator
  dummyDoc.defaultFillColor = dummyDoc.swatches.getByName("White, Black").color; // the default stroke color is set to a gradient swatch
  app.doScript("Action 2", "Test"); // execute an action which had been recorded to expand a gradient-filled shape to a Gradient Mesh. Actions can also be loaded and played via script.
  var opts = new IllustratorSaveOptions(); // new save options, they may not be even necessary
  dummyDoc.saveAs(dummyFile, opts); // save the document in the pre-specified file path
  app.activeDocument.close(); // close the document that was just saved
  var doc = app.activeDocument; // we are back to original document that was open
  var testLayer = doc.layers.add(); // add a layer which can be later removed
  var newPlaced = testLayer.placedItems.add(); // place the temp file into current document. Add a placed item and set its file to the previously defined file object.
  newPlaced.file = dummyFile;
  newPlaced.embed(); //embed the temp file to have the gradient mesh be interpreted as a non-native item.
  var originalNonNative = doc.nonNativeItems[0]; // now we have a Non Native item to manipulate.
  var newNonNative;
  var yCoord = 50;
  var xCoord = -80;
  var width = 150;
  var height = 100;
  for(var i = 0;  i< 3;  i++){ // cycle through the amount of items you potentially want
    newNonNative = originalNonNative.duplicate(doc.layers[1]); // create the non-native items using the duplicate function, send them to any layer. (except the test layer created by this script!)
    newNonNative.top = yCoord -= 100;
    newNonNative.left = xCoord += 175;
    newNonNative.width = width;
    newNonNative.height = height; // change any properties here
  testLayer.remove(); // clean up original open document by removing the test layer
test();
