My InDesign Windows friend said he can't open my InDesign CC 2017 Package on his computer.
My fonts aren't recognizable.
Thank you,
Morty
It is impossible to use Mac fonts on Windows. You’ll need to switch to OpenType fonts.
Hello, normally if it to the same version, no problems to open the Indesign document. But what fonts are used? There are restrictions on the fonts used.
Actually, it's not an InDesign question. That's about platform based fonts compatibility.
Short (and not at all detailed) answer could be:
To be on the safe side you should use OpenType fonts (those with OTF file extension). These are truly cross-platform.
Mac TrueType fonts only work on the Mac, while Windows TrueType fonts work on Windows and Mac. However, Mac TrueType fonts can be converted to the Windows version in order for it to work in Windows.
There are some other types you should avoid, like Data fork TrueType Suitcase (fonts with .dfont extension), etc. Windows won't read this.
Everything that has been said already is true. I work in a large pre-press and we keep one MAC workstation available to use because we have clients that send their labels in laid out on the MAC platform and they have MAC fonts in their packages which we can't use on the PC workstations. Personally I think we have things backwards at work. I think we should all be working on MACs and maybe have one PC workstation in the corner for PC related issues. But that is beside the point.
Assuming the guy you are sending the file to does not need to edit any of the text you could convert all the text to outlines before packaging it. This would eliminate the font issue. There are people who will say that you might lose a little quality. I personally believe that while that may be true it is not enough to be able to discern with the naked eye. Just my humble opinion.
Using OpenType fonts will resolve the issue as well regarding the crossing of platforms. But you probably don't want to buy new fonts. I get it.
Good Luck!
Randy, The Print Craftsman
A LITTLE quality?
Let's your friend replacing fonts on his PC and make a new package for you.
Since InDesign for Mac OS can use Windows fonts you will can work on the same document.
To expand on JR's response. If you place Windows TrueType or Type 1 fonts into the InDesign fonts folder, InDesign will be able to use those fonts.
However, I do not recommend it. Those fonts cannot be installed in the operating system and you do need to check on the licensing requirements. OpenType is a far better solution
I agree. I threw all my old fonts a few years ago and now I use OT fonts only.
