Bullets and indents
Participant ,
Jun 30, 2017 Jun 30, 2017
What does the cross symbol mean before the copy starts after the bullet in the attached screenshot. That a particular indent has been established? How do you change it?
717
Mentor , Jun 30, 2017 Jun 30, 2017
It's a special character Indent to Here
see for the complete list:
https://indesignsecrets.com/free-guide-to-indesign-special-characters.php
Special chars are searchable:
Mentor ,
Participant ,
Jul 05, 2017 Jul 05, 2017
Thanks. I've noticed that even though it appears to be aligned on the left when I print it doesn't look straight on the left side. Is there any way to tweak it to make sure it looks straight on the left side?
Participant ,
Actually the attached the screenshot to referenceScreen Shot 2017-07-05 at 11.07.27 AM.png
Mentor ,
Agreed to Barb - I don't see either.
If you're still unsatisfied with the overall look, maybe you could play with kerning: Metrics vs Optical (can be found in Control and Character palettes). However, it does nothing with the first character in a line.
Hey, characters aren't bricks of identical shape, so you can't expect visually perfect alignment...
I'm unclear why you are using it for a bullet list in the first place. It's a manual fix: someone had to add the bullet, press the space bar 5 times, and then add the Right Indent to Here character...on every paragraph. InDesign has a bullet feature which uses tabs as the separator and creates the hanging indent for you. It's quicker to apply, and quicker to edit.
It's not too late to create a style called bullet and then find that string and replace it with the bullet style.
As for the alignment: it's the font. I don't see an appreciable difference in the alignment when I use spaces and a Right Indent to Here character vs using a tab in the Bullets and Numbering dialog box. Do you?
