I've tried everything but the post process action does not fire unless it is open in photoshop.
I have placed a bunch of scripts in the Export Actions folder and tried them all, none of them are fired. I have tried applescript, shellscript both failed.
I have also tried "open in other application" and select my script there and that didn't work either!
I have tried "show in finder" and "open in photoshop" both works.
Please help! I ran out of ideas!
Is your script in the form of a droplet, using the "on open" handler to respond to open requests? You can test if the app you make is working correctly as a droplet by dragging a photo and dropping it onto the app in the Finder. AppleScript: Essential Sub-Routines
LR's Export will effectively "drop" the photo being exported onto the app, so it has to respond with "on open".
Hi Yarlag,
You may try and reset the Lightroom preferences back to defaults, maybe some of the settings under preferences causing this issue.
Preference file and other file locations | Lightroom CC and 6
Mohit
On Mac, Export's Open In Other Application can only run true Mac applications, not scripts. To run a shell script or an Applescript as an Export Post-Processing action, you'll need to package it as an app using Automator. I don't remember the details of how to do that, but Google will help: https://www.google.com/search?q=run+shell+script+from+automator&oq=run+shell+script+from+automator
Alternatively, use the Run Any Command plugin to run the script.
But I'm not using "open in other application", I'm using the export action folder where I place scripts in there. Is that not suppose to run scripts?
No, it's just a place to remember frequently used applications (things that can be run by Open In Other Application). See the help for details: Export presets, settings, and plug-ins in Lightroom . On Mac, that can only be apps or aliases to apps (on Windows, it can be executables or scripts).
Ok but even if that is the case, I have compiled the applescript into an app. And even that doesn't run in there.
How did you compile the script into an app?
You can make it an .app in the save dialog
I gave an absolutely incorrect answer -- LR on Mac can indeed run shell scripts as export post-process actions. See this post for details: Re: Export Post-Processing not working as expected . My sincere apologies for repeating a misremembered factoid without checking.
