Hello,
I am trying to figure out the best way for me to work between After Effects and Premiere. I have linked my AE comp to my premiere file. I AE comp shows up on my assets list in premiere and I can drag and drop that to the premiere time line. When I look at the properties of the imported AE comp I am seeing reduced quality. My after effects comp and my premiere sequence are set to the same resolution.
Why are the AE comps that I import so small?
Is the zoom in that comp's window in AE set to 100% or something else? How about its resolution -- full, half, third, quarter?
I should have replied directly to you. It seem that changing the resolution in AE solved the problem. I must have switched it before I left last night and this mourning everything was ok when I started it back up. Thanks for the answer. Who would have thought it would have been something so easy as making sure its at full!
