Locked
Links stop work after clicking them twice
Jul 05, 2017 Jul 05, 2017
Hello,
When I click on any link in a composition widget twice in a row all the links on the website become inactive.
I don't know if it helps, but here is a screenshot of the settings on the widget as well as the about screen for Muse.
I'm working on a MacBook Pro with macOS Sierra v.10.12.5.
Also, the website is http://omelcontrerasdesign.com/desirex_stage/
Thank you for your time,
Omel
Screen Shot 2017-07-05 at 6.20.49 PM.pngScreen Shot 2017-07-05 at 6.19.54 PM.png
571
LEGEND , Jul 11, 2017 Jul 11, 2017
the error is in your settings... just change hide target to none and it will work right
There seems to be a CSS effect applied to the triggers (the "scrolling eye").
What happens, if you remove this effect?
At first I thought the same thing.
I took the code out of the Metadat tab in the Page Properties.  I also deleted an overlay rectangle that showed the scrolling eye on the image above "Team Building" but the problem persists.
Here is that code:
<style>
  .img_overlay, .social_media {
     transition:  all 0.5s ease;
     -webkit-transition: all 0.5s ease;
</style>
Also if you look at the privacy policy (also in a composition widget)  in the footer, it does not have that CSS effect but also has the problem.
Thank you Gunter!
Thank you Gunter!
publish to Adobe BC as a free temp page and see if the problem goes away?
yes = talk to bluehost
no = give us a .muse file (just that privacy policy widget part wiil do) for testing.
oc259,
Okay, I put the site on bc
Home
Also, I put it back the way it was before.
Thank you in advance,
Omel
I meant to address the message to Ussnorway.
so you designed the site in muse then edited it in dreamweaver ... is removing "css_verticalspacer" from the css and adding phone code something bluehost needs?
in any event, I can confirm the code you posted isn't working on Adobe BC and I would take a close look at the text links... assume them first because of the way opens first time (with one click) but won't open again.
Jul 10, 2017 Jul 10, 2017
Sorry for taking so long to reply.
Okay, no I have not used Dreamweaver; I've only used Muse.
" is removing "css_verticalspacer" from the css and adding phone code something bluehost needs?"
No, bluehost does not need that.
I'm not sure what to do next.  Any ideas?
Give us a. Muse file (via Dropbox or a similar service) with only one page and  containing only the "misbehaving" elements
Okay, here is the file:
desirex_test.muse - Google Drive
Also, I put it on the business catalyst site at:
Home
Thank you!
Ussnorway,
Thank you! That worked!
Omel
This seems to be a configuration bug. The issue is reproducible with a simple composition dragged onto the canvas and configured as a lightbox.
I’ll report this in the prerelease forum.
Simple workaround: Set the „Hide Target“ option in the composition’s configuration panel to „None“, and all works as expected. Visually there is no difference at all.
Uuups! Ussnorway​ was faster!
Adobe Employee ,
Thanks for reporting the issue.
We will look into it.
quick and the dead
