Hello all,
I am working on Adobe CC 2017 on a Mac in InDesign and Illustrator and I am trying to copy the Die-line from Illustrator into Indesign for a packaging project as it is easier to mass produce in InDesign.
I am having an issue when I copy a vector based die line from Illustrator into InDesign. InDesign will end up placing it as a graphic instead of a vector, therefore I am unable to place my artwork under the die line to see where my folds and cuts will be.
I have been having this issue over the last few weeks and have not been able to find a way to be able to manipulate the vector any longer, be it adjusting the die line, or simply changing the color of a section of the vector. I will have to go back into illustrator to adjust, then copy and paste it back into InDesign repeatedly until it is correct.
Is there a simple fix to being able to paste actual vectors into InDesign like I was able to previously? Or is this a recent update that I will have to learn to work around?
Thank you for the help.
S
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from Comments forum to specific Program forum... Mod]
In InDesign: Edit > Preferences > Clipboard Handling.
Before copying from Illy, make sure all checkboxes in Clipboard section are unticked.
Thanks for your response Winterm, but this does not work. I unchecked the boxes in the Clipboard section, but Indesign still pastes the vector from Illustrator as a pasted graphic and I am unable to manipulate any anchor points.
Actually, that may have worked. I unchecked everything like you said and when I pasted it didn't work, although when I turned it back on, it worked. May have just needed reset or something? Thanks for the assistance!
Usually, the trick is what I mentioned in the first post: before copying from Illy.
If you copy, then paste, delete what pasted, change clipboard options and try to paste again - it won't work.
You need to go back to Illy and copy a 'fresh' copy.
Whatever, glad you worked it out.
