I was wondering if there is a way to loop through specific name objects (thru-cut) one at a time? I like to apply action commands to the objects indivdually. Is this possible?
You don't have the artboards being used as a property of a document object, are they still working for you?
Well I think your problem is that you specify your 'thru-cut' art as layers, while they are not layers. Layers have hasSelectedArtwork property, while art - or the items inside of layers - have the .selected property. In your case you'd change your code to: thisLayer.selected = true;
This is what I have so far.
#target illustrator
function test(){
function getPartialNamedItems(nameStr){
var doc = app.activeDocument, thisItem, arr = [];
for(var i=0; i<doc.pageItems.length; i++){
thisItem = doc.pageItems;
if(thisItem.name.match(nameStr)){
arr.push(thisItem);
return arr;
var allItems = getPartialNamedItems ("thru-cut");
app.doScript ('Artboards', 'Test');
//alert(allItems.length);
test();
now loop through your found items and perform an app.doScript on each of them after setting their .selected to true to select the items, and app.activeDocument.selection = null to deselect everything.
Thanks for your help Silly-V. I realize that the method I was using was incorrect. I won't be able to create the artboards using an action and that portion will have to be scripted. Here is what I have so far. No errors, but it isn't creating new artboards to the "thru-cut" objects like I need it to. Any chance you can help me with this? Thanks.
//get the total number of thru-cut in active document
function CutThruItems(nameStr){
arr.push(thisItem);
return arr;
var allCuts = CutThruItems ("thru-cut");
alert(allCuts.length);
//looping on layers to create one artboard per layer
for ( var i = 0 ; i < allCuts.length; i++)
var abIndex = i;
allCuts=true;
var sel = doc.selection
//Create the artboard around selected art
doc.fitArtboardToSelectedArt(abIndex);
artboards[abIndex].name = currentLayer.name;
//reset selection for next iteration
doc.selection = null;
You have to do something like var newBoard = doc.artboards.add([0, 100, 200, -100]);
Very close. I have the artboard showing but it is now its not resizing to the artwork.
//////////////////////////////////////////////get the total number of thru-cut in active document
arr.push(thisItem);
return arr;
//////////////////////////////////////////////Checkpoint of visible thru-cut starts here
for ( var i = 0 ; i < CutThruItems("thru-cut").length; i++){
var currentItem = CutThruItems("thru-cut");
//We don't want to deal with hidden layers
if(currentItem.visible == false) continue;
//Unlock the layer if needed
currentItem.locked = false;
//Select ALL in the layer
currentItem.hasSelectedArtwork = true;
//////////////////////////////////////////////Artboard creation starts here
if(i>0){
var newAb = artboards.add([0,100,200,-100]);
var thisLayer = CutThruItems("thru-cut");
thisLayer.hasSelectedArtwork = true;
doc.fitArtboardToSelectedArt(i);
//alert("Finished:\nRenaming of Artboards to match Layer names is complete");
