Breadcrumbs on Merged Projects
Oct 10, 2008 Oct 10, 2008
Has anybody run into an issue with breadcrumbs in the merged merged projects? Our WebHelp is structured as a master project with a number of other projects merged into it:
master.xpj:
- project1
- project2
----project2.1 (merged into project2)
- project3, etc
The breadcrumb works fine for the first two levels:
Home (master) > project1 > topic in project1
We run into the issue on the third level (project2.1):
Home (master) undefined Home (project2) > project2 > project2.1 > topic in project2.1
Any way around the undefined part?
485
Oct 13, 2008 Oct 13, 2008
Welcome to the forum
This does not surprise me. Merging within a merge can be tricky. Take a look inside the output files. I believe the breadcrumbs are hard coded on generation so maybe a find and replace would fix it?
Please post back if that works or you find some other solution.
Oct 21, 2008 Oct 21, 2008
quote:
Hi, Peter, thanks for the response. It doesn't apprear that the breadcrumbs are hard coded. From what I can tell, the output files call the AddMasterBreadcrumbs JavaScript function from the whtopic.js file and pass the link information into it. In either case, we have a great number of files, and a find and replace option would probably not be feasible.
Still looking for an alternative...
Advisor ,
Actually, when you say "a find and replace option would probably not be feasible" because of "a great number of files," it depends on the tool you'd be using. FAR (shareware) and BK ReplaceEm (freeware) are both recommended by many forum users, and you'd be surprised at how quickly you could perform your cleanup. The most difficult part is to identify exactly what text strings to key on for replacement. I'm not sure about BK ReplaceEm, but In FAR you can create a batch file that runs through multiple replacements on the same set of files.
Good luck,
Leon
Oct 22, 2008 Oct 22, 2008
quote:
Originally posted by: MergeThisFAR (shareware) and BK ReplaceEm (freeware) are both recommended by many forum users, and you'd be surprised at how quickly you could perform your cleanup. The most difficult part is to identify exactly what text strings to key on for replacement. I'm not sure about BK ReplaceEm, but In FAR you can create a batch file that runs through multiple replacements on the same set of files.
Thank you, Leon, very good to know! I'll take a look into FAR. You're right, the biggest challenge with this is to identify what to replace.
RoboHelp Documentation
Download Adobe RoboHelp
