Hey Guys! If anyone can help me with this issue I'm having that would be amazing!
I finally was able to get my button mouseover and mouseout scripts to work properly within Adobe Animate cc. Tested just fine, but when i bring the .oam into Muse, the mouseout script seems to be broken?
here is the script I'm using for the button
this.homeBTN.addEventListener("mouseover", over.bind(this));
function over()
this.LINE.gotoAndPlay("over");
this.homeBTN.addEventListener("mouseout", out.bind(this));
function out()
this.LINE.gotoAndPlay("out");
this.homeBTN.addEventListener("click", fl_ClickToGoToWebPage_2);
function fl_ClickToGoToWebPage_2() {
window.open("http://www.hausofmood.com", "_top");
Ive gone ahead and made it live on my site:
first Adobe Animate CC is not a good fit for Muse yet... I'm sure Adobe has a small team working on it but I wouldn't use it at this stage so Edge Animate is the better option.
i would assume you don't have all the codes enabled in your Animate template but its hard to tell without all the files... best of luck with it
I would not say that Animate CC is not a good fit for Muse yet. But making buttons using oam is absurd. Oam - is a complete HTML document, which is located in the iframe, but not just an object like <button>. Thus oam is suitable only for bannerers or animation decorations, but not for control elements.
Thanks! I suppose theres no other way to get that effect within Muse, and Ill just go into the code and work around it!
