Slow program response time despite high specs?
Jul 08, 2017 Jul 08, 2017
I am working on a 1.5 hr video using HD footage from multiple cameras and stabilizer effects as well as Magic Bullet plugins for color and lighting. Normally every thing works smoothly, I have a high-performance desktop I built specifically for this kind of work. Generally I haven't had any problems because projects I work on are much smaller then this one. As the timeline gets more busy the slow response is becoming unbearable. As far as I can see from various hardware monitors none of my hardware is being maxed out, besides when rendering, which is normal. When idle Ram is at 45% capacity, my media drive shows at most 50% of transfer bandwidth being used. Specs are below, any ideas on what might be causing the lag? Anything I can do to try optimizing the performance?
Specs:
Core i7 5820k
32gb DDR4 2666 (CAS 16)
ASRock x99 Taichi
RX480 Sapphire Nitro+
512GB M.2 SSD (2.3gb/s read / 1.4gb/s write), Primary drive for OS and Software
3TB 7200rpm, Secondary media drive
Premiere, drivers, and Windows 10 all up to date
[Moderator note: moved to best forum]
549
Valorous Hero ,
premiere has a long history of, and reputation for, falling apart on long timelines. there were several bugs supposedly fixed to help with this and prevent project file corruption, but perhaps they still haven't fixed everything. there is also the possibility of third part plugins somehow contributing to this. its often recommended to have more ram as the project length increases, so going to 64gb might help a little, but i doubt it would make a major difference. if you have the premiere project file and cache on the 3tb hdd, you might copy the project file to the os ssd and set the cache to the ssd too, to see if that helps.
beyond those things, the usual workaround is to split the edit into multiple projects, around 10-20 min long or small enough to keep the amount of imported media small for each project, and then combine each small project together to make the full edit. premiere can import other timelines from other projects, so combining the timelines from each smaller project can be done in a master project that only contains the imported timelines.
Thanks for the input. Unfortunately I don't have enough space on the OS drive to cache the project, might have to resort to breaking the project up as you mentioned, thanks!
Valorous Hero ,
its kind of a long shot, but you could still try copying over just the premiere project file. if its a large file it might be faster for premiere to read thru it on the fast ssd. i think the warp stabilizer also makes the project file alot larger as it writes that tracking data to the project file, so doing that stuff last might be better for editing performance.
Jul 13, 2017 Jul 13, 2017
You could try using "Render and Replace" on the stabilized footage and apply Magic Bullet from there.   With the stabilization rendered into the source footage at your Sequence settings, you should be able to get back to a more fluid editing experience.
-Warren
