Hello, i have script that I use in my workflow everyday but with new Illustrator 2017 I get an error.
The script is trying to find 4 spot color in document (Cut, Crease, Reverse crease and Outside bleed) and put every single color in own layer named as follows:
Spot color "Cut" > layer "Thru-cut"
Spot color "Crease" > layer "Crease"
Spot color "Outside bleed" > layer "Bleed"
Spot color "Reverse crease" > layer "Crease"
Script that I have used in old Illustrator is this:
#target Illustrator
//Apply to myDoc the active document
var myDoc = app.activeDocument;
//define firts caracter and how many layers do you need
var layerIniName =65;
var numberOfLayers=2;
//Create the layers
for(var i=0; i<=numberOfLayers; i++) {
var layerName = String.fromCharCode(layerIniName)
var myLayer = myDoc.layers.add();
myLayer.name = layerName
layerIniName++
// JavaScript Document
var doc = app.activeDocument;
// name indexed object
var layernames = {
'A':'Bleed / Grafika',
'B':'Crease',
'C':'Thru-cut'
// loop through all layers
for (var i = 0; i < doc.layers.length; i++)
//Set up Variable to access layer name
var currentLayer = app.activeDocument.layers;
if (layernames[currentLayer.name])
currentLayer.name = layernames[currentLayer.name];
var paths = doc.pathItems;
var destLayer = doc.layers.getByName ("Thru-cut");
for (var g=0; g<paths.length;g++){
if (paths
paths
var destLayer = doc.layers.getByName ("Crease");
if (paths
paths
var destLayer = doc.layers.getByName ("Bleed / Grafika");
if (paths
paths
if (paths
paths
Can anybody help me resolve this script with new Illustrator?
Denis
Sample file and script link:
https://www.dropbox.com/sh/hiffbk7yd3lspjg/AACdWhCbuMf2QC3fET8dd4mta?dl=0
Let's try to make things simple.
var main = function(layerCount) {
var doc, layers;
if ( !app.documents.length ) {
alert("This scripts needs an open document !");
return;
//The doc
//Adding useful layers
addLayers ( doc );
//Moving items onto specific layers
moveItems ( doc );
var moveItems = function ( doc ) {
var items = doc.pageItems, item, n = items.length, sc, tn, sn,
layers = getLayersDB(doc),
cutLayer = layers['Thru-cut'],
creaseLayer = layers.Crease,
bleedLayer = layers['Bleed / Grafika'];
while ( n-- ) {
item = items
; sc = item.strokeColor;
tn = sc.typename;
if ( tn =="SpotColor" ) {
sn = sc.spot.name;
if ( sn=="Cut") {
item.move(cutLayer, ElementPlacement.PLACEATBEGINNING);
else if ( /^(Reverse )?Crease$/i.test( sn ) ){
item.move(creaseLayer, ElementPlacement.PLACEATBEGINNING);
else if ( sn=="Outside Bleed") {
item.move(bleedLayer, ElementPlacement.PLACEATBEGINNING);
var addLayers = function ( doc ) {
var layers = getLayersDB ( doc );
var layerNames = [
'Bleed / Grafika',
'Crease',
'Thru-cut'
name;
while ( name = layerNames.pop() ) !layers[name] && addLayer ( doc, name );
var addLayer = function ( doc, name ) {
doc.layers.add().name = name;
var getLayersDB = function ( doc ) {
var db = {}, layers = doc.layers, n = layers.length, layer;
while ( n-- ) {
layer = layers
; db[layer.name] = layer;
return db;
main();
HTH
Thanks, will try this new script
Denis
