I'm working in a composition and I'll let my clips render for Ram Preview. But when I press the space bar to pause after it's done rendering, my Ram Preview bar restarts and disappears and I have to do it all over again. Sorry, I'm a bit new to After Effects, is there any solution to this?
Nobody can tell you anything without exact system info or other technical details like what's used in your comp, comp settings, disk cache settings etc..
Mylenium
Please give us the information Mylenium mentions so we can help you.
What, exact, version number of AE are you using?
Hi juluettez,
Still having preview issues? Let us know so that we can assist you.
Kevin
Hello! I resolved the problem with After Effects, but now I'm having the same exact problem with Adobe Media Encoder CC 2017. I read that with this error you have to "rename the file" but I'm not sure which file I'm supposed to rename and when I try to find the files from the error summary (as shown in the pictures attached) the file doesn't exist on my computer.
I would suggest creating a post about your Adobe Media Encoder issue over in Adobe Media Encoder (AME)​
Please provide them more information such as what operating system you are using, what you are doing when you run into the problem with AME, and what your settings are in AME.
Any chance you can mention how you got the AE green bar back?
I'm not sure this is the case, but I would like to leave here a little hint. I had the same (or similar) problem - green bar suddenly dissapeared. But in my case what caused it was... a mistake in keybord shortcut I have pressed. You see, there is a default shortcut for Switch Fast Previews to Fast Draft which is Ctrl+Alt+4. I have pressed that combination by mistake and there was apparently no sign of anything happening... but green bar was gone. I said 'apparently', because then I have noticed a little change in the icons below main preview panel:
I love you, thanks
