Hello,
I have never had any troubles with Adobe Premiere Elements 14, but I have recently run into quite a few of them.
I have been trying to edit .avi video files together, and I critique it to look good. Inside of the video software, the video looks exactly how I want it: the audio, music, and video all line up seamlessly. However, once I export it, the video clips are trimmed completely differently: the parts that I cut out play, while the parts that I want to play are cut out. The audio and music are unaffected, but all of the video is messed up.
The finished video isn't particularly long, only about 2 minutes, so this comes as a surprise to me. I have never had this problem before, and some google searching has showed that not many people have had this problem.
I just don't know where to start. Any feedback is greatly appreciated.
Thank you.
The solution is to convert the video to Constant Frame Rate using the free download Handbrake.
What model of camcorder is this video coming from? What is the video's resolution and format?
The out of sync issues happens most often when working with video from non-camcorder sources. Screen recording software, for instance, often records the video with a variable frame rate.
The video is a screen recording by Debut Recording Software. The thing is, I have never had any problems with this software before. I have edited many videos of this kind in Adobe Premiere Elements, and this problem has never occurred
That worked like a charm! Thank you so much for your help!!
