Hi guys
I have several art boards in one ai file and have saved then as separate projects. I have separated the layers in each separated illustrator project and exported it as an ai file. I am struggling to import illustrator files into after effects...Firstly it doesn't import them as separated layers to animate and second it doesn't open the file I saved it as. It opens the same project every time even if I import a different ai project altogether. On import I tick the composition retain layer sizes option ...
Please help
It's very hard to decipher what's going on from this description. Is it possible to post a copy of the Illustrator file in question? I'm happy to assess it for you.
Hi Andrew
I don't how to post the pics and write...The above pic is the different art boards I separated into saved as single ai projects.
Below is a one of the single projects I have saved from the above large ai file above
As you can see I have separated all the art work onto their own separate layer. As you can see I have all the separated and importing the exact project saved from ai.
Below is a pic from what is imported into after effects and as you can see it isn't the same project and even I I try to import a different project I get the same project imported
Any help will be appreciated
I can't tell for sure from the screen grabs, but it looks like AE is assuming this is 30 frames of an animation. I think it is bringing in all of your files, but creating a sequence that has each file as 1 frame of the sequence. When you do the import did you select "footage" or "file"?
Hi Brian
I chose file and chose the "compistion retain layer sizes" option
You have illustrator/PDF/EPS turned on at the bottom of the import dialog box in the above image. Uncheck it and your files will import at separate source footage.
Katie is correct. Uncheck the box indicated with the arrow below. When it is checked, rather than import it as a still image, it is importing all your images as a sequential video animation.
Hi siraajl,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
