Can not parse file, file is damaged. I can't import image sequences on the current Ae. These sequences import fine using 2014. Anyone having the same problem? I posted a question regarding the parse file issue a couple days ago (35 :: 45) but no one responded. I work almost exclusively in images sequences so I would like to resolve this issue.
Thanks.
Is it just this particular sequence or all sequences? Can you copy the files to another drive to test import from to eliminate it being disk error? What happens if you import into 2014 and then open that document into the new AE and use that. I know it's a pain i'm just curious if it still works to try and trouble shoot to locate the problem.
Hi scott_mo,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
Moving this convo to here. Thanks.
Image sequence problem: Can not parse file error 45 :: 35?
Sorry about that. HERE!
