Hi!
I am editing a property -- Position -- in the Graph Editor. It's the position of a Repeater's transform. For whatever reason, I can add easy-ease to the motion's keyframes, but there are no Bezier handle on the keyframes themselves. The option to separate the x and y components is greyed out (both the button on the bottom and the option in the right-click menu), and I have unchecked "Use Linear Vertex Paths" under Mask Interpolation. Even using the Convert Vertex tool does not work. I have read up on this in the forums, and maybe there's a solution, but those things I listed were the only bits I could find that might have helped, and none worked (unless of course I missed something, which is entirely possible; it's Tuesday, after all, and I never could get the hang of Tuesdays).
How do I get handles so I can edit this?
Thanks in advance!
position keyframes don't get bezier handles unless you separate them and you can't separate any property other than transform position of the layer.
this is not related to bezier handles for position, but to the way the vertices of a mask can move (straight line or curved)
how are you using it? if you are using it to convert temporal linear keyframe to auto bezier - it works in the graph editor
you might want to get information by reading the help files and not the forums.
Managing and animating shape paths and masks in After Effects
I have read lots of help files and will continue to; trying to find the detail you're looking for is often a needle in a haystack, which is why I am glad communities like this exist.
Either way, thanks for the input; I appreciate your time and effort answering my question!
Glad to help. Thanks for the feedback.
