SOLVED
AEM 6.1 Single-Sign-On(SSO) with OKTA
Avatar
Former Community Member
What problem we are solving?
Configure AEM6.1 to allow authors to login to /projects.html using OKTA.
What's done?
Configured AEM6.1 author per the steps specified in the document-http://www.aemstuff.com/blogs/july/saml.html
Have we done OKTA integration with AEM6.1?
Yes; it's working in our Production environment; we created new test environment from scratch, OKTA SSO not working for the new author environment.
Issues we are facing: Not able to login to author using our network username & password.
  • CQ Author level:
    • Server logs:
      • 05.07.2017 23:30:45.683 *WARN* [qtp535806943-32583] com.adobe.granite.auth.saml.SamlAuthenticationHandler Private key of SP not provided: Cannot sign Authn request.
      • 05.07.2017 23:32:03.085 *WARN* [qtp535806943-31835] com.adobe.granite.auth.saml.SamlAuthenticationHandler Could not retrieve SP's private key: Uninitialised key store for user authentication-service
ASK?
  • What could be causing above errors? How to resolve them?
  • Any known SSO bug with AEM 6.1?
1 Accepted Solution
Avatar
Correct answer by
Thanks.
I'm able to resolve the issue. I made changes few changes - (1) Apache config changes (2) Author & groups permissions were missing.
Avatar
Level 9
Hi Guru,
   None of the log message you mentioned is nothing to worry about.  Issue sounds to be different that saml.
Enable debug on   com.adobe.granite.auth.saml.SamlAuthenticationHandler and then repeat the test case and send us logs, osgi config snapshot and har file.  Generating HAR files and Analyzing Web Requests - Atlassian Documentation
Avatar
Correct answer by
Thanks.
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
