ColdFusion 2016 has modified the usage of CFloop tag.
Jul 12, 2017 Jul 12, 2017
We are migrating from ColdFusion 7 to ColdFusion 2016. When I used ColdFusion Code analyzer, I got the following error message. The specification of the code is unknown. Can anyone teach me?
CFLOOP (9)
Solution
Check the usage of the tag CFloop.
E:/wwwRoot/Extension/udf/Scr_UDF.cfm ⾏ 224
<!--And sets the acquired value-operational years in array-->
<cfloop index="date" to="#q.YM + 1#" from="#variable.nowYM#" step="-1" >
1.3K
Advocate ,
ColdFusion Help | cfloop
Cant see anything wrong with the loop you posted though.
Thank you for your instruction.
I will send all contents of this file. Please confirm once again.
Thank you.
<cfinclude template="scr_check_UDF.cfm">
<cfinclude template="scr_menu_UDF.cfm">
<cfinclude template="scr_grid_UDF.cfm">
Function name: sanitizeInput
Summary: Perform sanitization processing.
Arguments: str: string: String to be sanitized
Type: String: Type of sanitization
Return value: ret: string: sanitized character string
<cffunction name="sanitizeInput" returntype="string" access="public">
    <cfargument name="str" required="yes">
    <cfargument name="type" required="no">
    <cfset ret = arguments.str>
    <cfset argType = "">
    <cfif isDefined("arguments.type") is "True">
        <cfset argType = arguments.type>
    </cfif>
    <cfswitch expression=argType>
        <cfcase value="html">
            <cfset ret = REReplaceNoCase(ret, "<[^>]*>", "", "ALL")>
        </cfcase>
        <cfcase value="sql">
            <cfset ret = REReplaceNoCase(ret, ",|'", "", "ALL")>
        </cfcase>
        <cfdefaultcase>
        </cfdefaultcase>
    </cfswitch>
    <cfreturn ret>
</cffunction>
Function name: chkUserAuth
Summary: User authority check function
Argument: str: string: Screen ID
Return value: ret: boolean: true = Authorized false = No authorization
<cffunction name="chkUserAuth" returntype="boolean" access="public">
    <cfargument name="str" type="string" required="yes">
    <cftry>
        <cfset chkUserAtuhSql = "
            SELECT
                USER_ID
            FROM
                MA_AUTH
            WHERE
                USER_ID = '" & getLoginUser() & "'
                AND SCRREP_ID = '" & str & "'
                AND DELETE_FLG = '0'
        <cfquery name="rs" datasource="#request.dsn#">
            <cfoutput>#PreserveSingleQuotes(chkUserAtuhSql)#</cfoutput>
        </cfquery>
    <cfcatch>
        <cfreturn false>
    </cfcatch>
    </cftry>
    <cfif #rs.Recordcount# EQ 0>
        <cfreturn false>
    <cfelse>
        <cfreturn true>
    </cfif>
</cffunction>
<!--- Check CSV output permission from login ID --->
<cffunction name="getCsvAuth" returntype="boolean" access="private">
    <cfargument name="get_gid" required="yes" type="string">
    <cfquery name="csv_auth_rs" datasource="#request.dsn#">
        SELECT
            CSV_OUTPUT_AUTH_FLG
        FROM
            MA_AUTH
        WHERE
            USER_ID = '#getLoginUser()#'
        AND SCRREP_ID = '#get_gid#'
    </cfquery>
    <cfif csv_auth_rs.recordCount EQ 0>
        <cfreturn false>
    <cfelseif csv_auth_rs.CSV_OUTPUT_AUTH_FLG eq "1">
        <cfreturn true>
    <cfelse>
        <cfreturn false>
    </cfif>
</cffunction>
Function name: getKbnList
Summary: Acquire and return the code list of the class specified by argument from the name master
Argument: kbn: string: category code
: Flg_check: boolean: If TRUE, check the deletion flag
: Str_in: string: comma separated value extraction condition
Return value: ret: struct: result structure
Cd: Generic type code
Name: Generic type name 3 (Kanji abbreviation)
<cffunction name="getKbnList" returntype="struct" access="public">
    <cfargument name="kbn" type="string" required="yes">
    <cfargument name="flg_check" type="boolean" required="no" default="true">
    <cfargument name="str_in" type="string" required="no" default="">
    <!--- Return structure structure --->
    <cfset retList = structnew()>
    <cfset structinsert(retList, "cd", ArrayNew(1), true)>
    <cfset structinsert(retList, "name", ArrayNew(1), true)>
    <!--- Set of blank lines --->
    <cfset retList.cd[1] = "">
    <cfset retList.name[1] = "">
    <!---If the argument is blank, it returns only blank lines--->
    <cfif arguments.kbn EQ "">
        <cfreturn retList>
    </cfif>
    <cfset strCondition = "">
    <!---If an extraction condition is set, a WHERE clause is set--->
    <cfif str_in neq "">
        <cfset strCondition = " AND A.GEN_PUR_KIND_CD IN (#str_in#)">
    </cfif>
    <!--- DDB search --->
    <cftry>
        <!--- Search records with category code argument kbn --->
        <cfif flg_check eq true>
            <cfquery name="getKbn" dataSource="#request.dsn#">
                SELECT
                    A.GEN_PUR_KIND_CD AS CD,
                    A.GEN_PUR_KIND_NM_3 AS NAME
                FROM
                    MT_NAME A
                WHERE
                    A.CATEGORY_CD = '#kbn#'
                AND A.DELETE_FLG = '0'
                #strCondition#
            </cfquery>
        <cfelse>
                SELECT
                FROM
                    MT_NAME A
                WHERE
                    #strCondition#
            </cfquery>
        </cfif>
        <cfif #getKbn.recordcount# lte 0>
            <!--- If no record was found --->
            <cfreturn retList>
        </cfif>
        <cfcatch type="database">
            <!--- Database error --->
            <cfreturn retList>
        </cfcatch>
    </cftry>
    <!--- Store acquired data in array --->
    <cfset i=1>
    <cfoutput query="getKbn">
        <cfset i=i+1>
        <cfset retList.cd[i] = CD>
        <cfset retList.name[i] = NAME>
    </cfoutput>
    <cfreturn retList>
</cffunction>
Function name: getTransYM
Summary: Return processing year based on closing date master
Argument: None
Return value: ret: array: YYYYMM format processing year / month (character string)
<cffunction name="getTransYM" returntype="array" access="public">
<!--- Generate an array --->
<Cfset variable.ret = arrayNew (1)>
<!--- Get operation date --->
<Cfset variable.nowDate = getOperationYMD ()>
<!--- Obtain operation date --->
<Cfset variable.nowYM = getTheMonth (variable.nowDate)>
In the case of
<!--- Index of Index --->
<Cfset variable.index = 0>
In the case of
<Cftry>
<!--- "Closing day master" reading --->
<!--- Fastening day is less than current day, acquire latest closing date --->
<cfquery name="q" datasource="#request.dsn#" maxrows="1">
            SELECT
                YM
            FROM
                MT_TIE_DAY
            WHERE
                DELETE_FLG = '0'
             AND
                TIE_YMD < '#variable.nowDate#'
            ORDER BY
                YM DESC
        </cfquery>
<!--- Data check --->
<!--- Perform acquisition processing only when the acquired value is numeric & 6 digits --->
<Cfif IsNumeric (# q. Y #) is true and len (# q. Y #) eq 6>
<!--- Set acquisition value ~ operation year to array --->
<Cfloop index = "date" to = "# q.YM + 1 #" from = "# variable.nowYM #" step = "- 1">
In the case of
<!--- Ignore except 1 to 12 in the last 2 digits --->
<Cfif Right (date, 2) le 12 and Right (date, 2) ge 1>
<!--- Set to array --->
<cfset variable.index = variable.index + 1>
                    <cfset variable.ret[variable.index] = date>
                </cfif>
            </cfloop>
        </cfif>
            <!---If a DB exception occurs, it outputs an error in the log and returns false--->
            <cfset variable.array = arrayNew(1)>
            <cfset writeLog("FS0001", "SDC101.cfm", "setDistName", variable.array)>
        </cfcatch>
    </cftry>
    <!---When none of the data is registered--->
    <cfif variable.index eq 0>
        <!---Keep only the year of operation--->
        <cfset variable.ret[1] = variable.nowYM>
    </cfif>
    <!---Return array type--->
    <cfreturn variable.ret>
</cffunction>
Function name: getScrRepName
Summary: Obtain the screen of the argument gId · the screen of the form ID · the form name
Argument: gId: string: screen · form ID
Return value: ret: string: screen / form name
If the screen can not be found return null character
<cffunction name="getScrRepName" returntype="string" access="public">
    <cfargument name="gId" required="yes">
    <cfset var ret = "">
    <!---Exit if gid is blank--->
    <cfif arguments.gId eq "">
        <cfreturn ret>
    </cfif>
    <cftry>
        <cfquery name="q" datasource="#request.dsn#">
            SELECT
                SCRREP_NM
            FROM
                MA_MENU
            WHERE
                SCRREP_ID = '#arguments.gId#'
        </cfquery>
        <cfcatch>
            <cfreturn ret>
        </cfcatch>
    </cftry>
    <cfif q.recordcount eq 1>
        <cfset ret = q.SCRREP_NM>
    </cfif>
    <cfreturn ret>
</cffunction>
Function name: getLoginUser
Summary: Retrieve the user ID of the currently logged-in user from the session variable
Argument: None
Return value: User ID
<cffunction name="getLoginUser" returntype="string" access="public" output="no">
    <cfset var user_id = trim(session.user_id)>
    <cfreturn user_id>
</cffunction>
You should replace the HTML comment with a ColdFusion comment:
​<!--- And sets the acquired value-operational years in array --->
Jul 13, 2017 Jul 13, 2017
Dear Mr.BKBK
Thank you for your solution.
I check the ColdFusion comment.
Thank you.
Documentation
