Localisation problem
Jul 11, 2017 Jul 11, 2017
Friends and experts,
On my English Win7-x64 with FrameMaker 14.0.2.425 (en) I have this very simple script, which I also tested on the machine of my wife (Win7-x32, German) with the German version of FM 14.0.2.425:
/* ETBtest.jsx
   To be placed in Startup folder of user area */
#target framemaker
alert ("Testing $.locale= " + $.locale);
var gsETBtest_title = { en: "Testing a jsx script in %apdata%\...\FrameMaker\vv\Startup [ETB]",
                        de: "Test eines jsx scripts in %apdata%\...\FrameMaker\vv\Startup[ETB]"
var gsETBtest_msg   = { en: "Befor You test your own script, rename this script to ETBtest-ori.jsx"
                          + "\n• Name Your script ETBtest.jsx"
                          + "\n• You can now invoke it from the ETB tool-bar Extra (last icon)."
                          + "\n\nAfter your tests please rename ETBtest-ori.jsx back to ETBtest.jsx",
                        de: "Vor dem test Ihres scripts bitte dieses script auf ETBtest-ori.jsx umbenennen"
                          + "\n• Benennen Sie ihr script ETBtest.jsx"
                          + "\n• Nun kann ihr script von der ETB tool-bar Extra (letztes icon) aufgerufen werden."
                          + "\n\nNach den tests bitte ETBtest-ori.jsx zurück benennen auf ETBtest.jsx"
var gsETBtest_NoDoc = { en: "No book or document active",
                        de: "Kein buch oder dokument aktiv"
SetUpMenu();                                      // out-comment for debugging
function SetUpMenu() { // =========================================================================
// This function MUST NOT be named DefineMenu - because this is a reserved function!
// Errors in ESTK: Menu position can not be changed - see bug report FRMAKER-2752
// No menu is defined here - it is set up in customui.cfg / menus.cfg
  var cmdDoc = DefineCommand (1, "ETBtest", "Test a script [ETB]", "");
  UpdateMenus();
} // --- end SetUpMenu
function Command(cmd) { // ========================================================================
    switch(cmd)  {                                    // Respond to menu command.
        case 1:
      WhatIsToDo();
      break;
} // --- end Command
function WhatIsToDo () { // === This is what the test script will do ===============================
  alert (localize(gsETBtest_msg), localize(gsETBtest_title));
  return;
On my English system/FM the alert reports
  Script Alert
  Testing $.locale= 2
and the invoked script (by button) reports the en message from the gsETBtest_msg object.
On the German system/FM the alert reports
  Script Fehler
  Testing $.locale= 3
I get the German 'reaction' of the script only if I insert on the top of the script - which of course is not very useful for a bi-lingual script:
  $.locale = "de";
What goes wrong here?
The method is described in JavaScript Tools Guide of CS5.
By the way: changing the order of the string declarations (have de first, en second) has no effect on both systems.
Scripting
327
Community Expert , Jul 12, 2017 Jul 12, 2017
The solution with the automatic localisation is not bullet proof:
My system is in English (Windows, FM and all apps which provide this UI language). The input language (keyboard) is de-CH) which will trigger German in the scrips. Hence I need  a longer way - a function to switch the UI language:
function SwitchLanguage () {; // === Switch language according to application language ============
  switch (app.Language) {
    case Constants.FV_LANG_BRITISH:
    case Constants.FV_LANG_ENGLISH: {
      $.l
Well, most likely the cause is the missing ESTK tool kit - which is not contained in TCS7. Hence I could not install it on the German system.
Since only used for a test period I will install it from TCS6 and look further.
The installation of ESTK 3.5 (which is free and not a cloud stuff) did only help in one point: in FM File > Scripts > New Script opens ESTK.
However, the script still does not automatically adapt to the language of the application FM. So I introduce the script with this:
$.locale = app.Language;    // 2: en; 3: de, 4: fr
if ($.locale = 3) {
    $.locale= "de";
or with forcing the automatic localisation by
$.localize = true;
The necessity of this is - however - not clear from the documentation (JavaScript Tools Guide of CS5) which states on page 104:
The localize function always performs its translation, regardless of the setting of the $.localize
variable. For example:
//Only works if the $.localize=true
   b1 = w.add ("button", undefined, btnText);
//Always works, regardless of $.localize value
   b1 = w.add ("button", undefined, localize (btnText));
This "Regardless of the setting of the $.localize variable" is simply wrong.
Klaus
      $.locale = "en"; break;
    case Constants.FV_LANG_CANADIAN_FRENCH:
    case Constants.FV_LANG_FRENCH: {
      $.locale = "fr"; break;
    case Constants.FV_LANG_GERMAN:
    case Constants.FV_LANG_NEW_GERMAN:
    case Constants.FV_LANG_NEW_SWISS_GERMAN:
    case Constants.FV_LANG_SWISS_GERMAN:    {
      $.locale = "de"; break;
    default: {
} // --- end SwitchLanguage
