Adding Clipboard as content source would have several advantages. For example, you could create a new document from clipboard and paste automatically the clipboard in that document. Ctrl-N,Enter would do the same trick.
Hi Dario
You can do that now albeit with one more key press.
With an image on the clipboard just go to Photoshop and Press Ctrl+N, Enter then Ctrl+V
Dave
Things like that can be scripted easily. You can do things like append the contents of the clipboard to a document and expand the document canvas for the size of the clipboards content and position the clipboard's contents over that area.
// 2013 John J. McAssey (JJMack)
// This script is supplied as is. It is provided as freeware.
// The author accepts no liability for any problems arising from its use.
// I set a shortcut key in my case F5 to this Photoshop script mainly for doing Window screen capturing of:
// desktop displays, Active window and selected area copy to clipboard. The script log the cardboard into a document with the name clipboard.
<javascriptresource>
<about>$$$/JavaScripts/AppendClipboard/About=JJMack's Append Clipboard into Clipboard document.^r^rCopyright 2014 Mouseprints.^r^rJJMack's Script.^r
NOTE:New Clipboard Document will be open if necessary</about>
<category>JJMack's Script</category>
</javascriptresource>
// enable double-clicking from Mac Finder or Windows Explorer
#target photoshop // this command only works in Photoshop CS2 and higher
// bring application forward for double-click events
app.bringToFront();
if (!documents.length) {
NewCliboardDoc ();
app.activeDocument.suspendHistory('appendClipboard','main(true)'); // New document opened proceed
else { //locate Document clipboard
for (var i=0;i<app.documents.length;i++) {
app.activeDocument=app.documents;
if (app.activeDocument.name == "Clipboard"){break;}
if (app.activeDocument.name != "Clipboard"){
NewCliboardDoc ();
else {app.activeDocument.suspendHistory('appendClipboard','main(false)'); } // Old Clipboard Document found
// main function //
function main(newFile) {
// declare local variables
var orig_ruler_units = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS; // Set the ruler units to PIXELS
try {
activeDocument.paste(); // past in clipboard may fail enclose in try
var LB = app.activeDocument.activeLayer.bounds; // Get the bounds of the work layer
var LWidth = (LB[2].value) - (LB[0].value); // Area width
var LHeight = (LB[3].value) - (LB[1].value); // Area height
// BOTTOMCENTER BOTTOMLEFT BOTTOMRIGHT MIDDLECENTER MIDDLELEFT MIDDLERIGHT TOPCENTER TOPLEFT TOPRIGHT
if(newFile) {
app.activeDocument.resizeCanvas(LWidth, LHeight, AnchorPosition.TOPLEFT);
app.activeDocument.layers[1].remove();
else {
if (LWidth>=app.activeDocument.width) { app.activeDocument.resizeCanvas(LWidth, app.activeDocument.height + LHeight, AnchorPosition.TOPLEFT);}
else {app.activeDocument.resizeCanvas(app.activeDocument.width, app.activeDocument.height + LHeight, AnchorPosition.TOPLEFT);}
app.activeDocument.selection.selectAll(); // select all
// Left('AdLf'); Right('AdRg'); Top('AdTp'); Bottom('AdBt'); Center Horizontal('AdCH'); Center Vertical('AdCV');
align("AdLf");align("AdBt"); //Align to selection Left bottom
app.activeDocument.selection.deselect();
SetViewFitonScreen();
//app.purge(PurgeTarget.CLIPBOARDCACHE);
catch(e) {
if(newFile) app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
alert("Clipboard Empty");
app.preferences.rulerUnits = orig_ruler_units; // Reset units to original settings
// main function end //
function NewCliboardDoc () {
// app.documents.add([width][, height][, resolution][, name][, mode][, initialFill][, pixelAspectRatio][, bitsPerChannel][, colorProfileName])
var Clipboard = app.documents.add( null, null, 100, "Clipboard", NewDocumentMode.RGB, null, null, null, "sRGB IEC61966-2.1");
function align(method) {
var desc = new ActionDescriptor();
var ref = new ActionReference();
ref.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
desc.putReference( charIDToTypeID( "null" ), ref );
desc.putEnumerated( charIDToTypeID( "Usng" ), charIDToTypeID( "ADSt" ), charIDToTypeID( method ) );
executeAction( charIDToTypeID( "Algn" ), desc, DialogModes.NO );
function SetViewFitonScreen() {
var desc1 = new ActionDescriptor();
var ref1 = new ActionReference();
ref1.putEnumerated(charIDToTypeID('Mn '), charIDToTypeID('MnIt'), charIDToTypeID('FtOn'));
desc1.putReference(charIDToTypeID('null'), ref1);
executeAction(charIDToTypeID('slct'), desc1, DialogModes.NO);
SuspendHistory : does this work in VBSCRIPT
