1TheMacBob1, I've been experimenting and find that editing
the xml file works fine for me, but I noted some differences
between my xml file and yours which make me wonder if we are using
the same version of Presenter, or if I am using different settings
than you are. I'm currently using the trial version of 7.01. I'm
using an FLV video, displayed in the sidebar.
I did notice that in the example you gave, the flvcontents
tag is missing its opening tag, which might cause problems.
I'm providing you with the code for my first 2 slides which
you can compare to yours and see if you see anything significant.
I found that no matter what I do, it hardcodes builds into
the swfs so that they execute very fast. It ignores any settings in
the xml file. When I decompiled the relevant swfs for the slides
with builds they were in there set to about a half-second each. So
now I am re-doing the powerpoint with builds made as separate
slides.
Here is my code for the first to slides:
<!--title slide 1-->
<slide id="262" frameRate="30" totalFrames="270"
advance="auto" blockMovement="false" type="normal">
<content url="Slide1.swf"/>
<slideBackground index="0" frameToPlay="1" duration="2"
showAfterFrame="0"/>
<flvContents></flvContents>
<slideTitle>Mathematics and Music</slideTitle>
<notes isHTML="true"></notes>
<video url="master_262_2_60791.flv" StartTime="0.000000"
StopTime="338000.000000" MuteAudio="0" IsH264="0"/>
<slideThumbnail url="thumb.swf" frame="1"/>
<slideSpeaker index="0"/>
</slide>
<!--slide 2 simple premises-->
<slide id="327" frameRate="30" totalFrames="270"
<content url="Slide2.swf"/>
<slideBackground index="1" frameToPlay="1" duration="2"
<clickAnimations>
<clickAnimation start="1" end="16"/>
</clickAnimations>
<slideTitle>Simple Premises</slideTitle>
<notes
isHTML="true">Both musicians and mathematicians create patterns of great variety, beauty, and subtlety from the simplest of premises. <br></notes>
<video url="master_327_2_90620.flv"
StartTime="338000.010000" StopTime="388000.875000" MuteAudio="0"
IsH264="0"/>
<slideThumbnail url="thumb.swf" frame="2"/>
</slide>
