Is there a way to use the same vector mask for multiple layer groups?
I have several groups that are marked as .png so that they automatically export to .png files. I use a separate but identical vector mask for each group. This works, however it's very time-consuming to keep all the masks "in-sync". It would be great to be able to use one vector mask for all the groups. Can this be done?
The Group needs to have a Blend Mode other than »Pass Through«.
Well, sort of. Layer masks are quite limited in Photoshop, and the only work-around is to create your vector mask, convert that layer to a smart object, and use that smart object as a clipping mask. To re-use the same mask, duplicate the smart object, and use as a clipping mask again.
Trouble with this method: in-place, real-time editing of your masks is impossible, which is awkward when you need to precisely edit the mask based on the existing content in the master document.
One would think the developers would have improved the layer mask system in the second decade of the 21st century (at least allow for instancing layer masks across the layer stack), but nothing really changed since Photoshop 4/5. A shame. Other image editors do a better job now, and Photoshop is left behind in this regard.
Another option would be to use a Knockout-Layer instead of a Clipping Mask.
That might work if we figure out a way to use clipping masks on groups
Ah, yes - forgot about that. Convert groups to smart objects first, then?
Thanks again. Yes, this will also work. I'm marking c.pfaffenbichler's answer as correct because it involves less steps, but I'm sure your approach will be useful for some people.
Hi
Without seeing you layer structure it is hard to see if this would apply but can you not just nest the groups within a larger group and apply the vector mask to that?
Dave
Dave, thank you for the suggestion, but this won't work because I have several groups that are marked as .png so that they automatically export to .png files. So, if I combine those groups into a "super-group" and use a mask on that group, it will be ignored when the .png files are created.
The Smart Object as a Knock-out Layer in Groups (set to Blend Mode other than »Pass Through«) could also work and not cause problems if the Group contains Groups itself.
Sorry, I'm not familiar with Knock-out Layers. Could you please post a screenshot?
