About creating shapes from vector layers
Jul 13, 2017 Jul 13, 2017
Hello everyone, I am having trouble using AE. When I draw a pattern in AI, and only solid fill, and then import AE, and then use "creating shapes from vector layers", AE work properly. However, if you use AI to draw a pattern, use the gradient fill, then import AE, and then use "creating shapes from vector layers", it will show an error.So, how should I use the gradient when the normal use of "creating shapes from vector layers"
3.3K
LEGEND , Jul 13, 2017 Jul 13, 2017
no. Illustrator gradients Don't retain appearance when converted to shapes. You are left to recreate them using a shape gradient fill or effects/layer styles.
Gradients, or any opacity/blend mode changes to your illustrator layers, turn off or grey upon converting to shape layer. this is a limitation of the conversion we unfortunately have to live with. you can recreate the gradient in Ae if you want by simply adding a gradient fill for the shape layer. you should also read this explanation by Rick Gerard about the necessity of even using create shapes from vector layers : Re: Imported Illustrator shapes with gradients turning gray after creating shapes from vector layer ...
I checked Rick Gerard's answer, but the question is that there is no need to convert, but my job needs such a function, so there is no way to solve it?
If you must convert Vector paths (Illustrator layers) to Shape layers and you don't want to mess with manually recreating the fills you need to design the artwork in Illustrator in a way that the conversion will work and the appearance will be maintained. This limits your design options but is the only time efficient work around.
It's something like putting new tile in the shower. You want to use tiny 1/2" square tiles and they come in sheets with 200 tiles all uniformly spaced out on a sheet of tile so they are easy to install.
When you start installing the tiles you decide that you don't like the pattern at all. You have a choice, live with the pattern in get the job done in a reasonable amount of time or cut the sheets apart and install each little square one at a time. It's the same way with Illustrator files that you must convert to shapes.
Thanks for the illustration Rick. where do you find such a tasteful tile design I wonder...
Nov 29, 2020 Nov 29, 2020
Hi, I too have come across the same issue where I have used a gradient fill in Illustrator and I still get that grey colour after converting to shape layers in after effects. Has anyone here managed to find another workaround as opposed to manually redoing the gradient fill in after effect ? An update on this would be greatly appreciated.
