      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
coldfusion 2016 install on Centos 7 apache control script
Jun 29, 2017 Jun 29, 2017
I am trying to install
Coldfusion 2016 on a CentOS 7 Linux machine  with an Apache Web Server
also, same problem with Coldfusion 8 on a CentOS 7 Linux machine  with an Apache Web Server
The install script prompts for the "apache control script",
The script does NOT exist.
CentOS now controls the services via systemctrl
How do I get the install to work?
Any ideas?
I have skipped the web server configuration part of the install.
Apache will just displays coldfusion scripts as text.
I have tried using wsconfig, but doesn't work. (The 'ok' button is greyed out.
I have tried to hack the httpd.conf file, but that doesn't not work.
Any ideas?
I have modified the httpd.comf
to use mod_run. still not working.
I have extracted the mod_jrun "so" files
as outline in this link
https://www.apachelounge.com/viewtopic.php?p=5352
3.1K
Adobe Employee ,
Jul 12, 2017 Jul 12, 2017
Could you please confirm, if you are using CentOS built-in Apache.
You can run the connector command from \coldfusion2016\cfusion\runtime\bin. Use the below command.
./wsconfig -ws Apache -bin /usr/sbin/httpd -script /usr/sbin/apachectl -dir /etc/httpd/conf/ -v
Priyank
Priyank Shrivastava
Adobe Employee ,
Jul 13, 2017 Jul 13, 2017
Could you please confirm, if above command works for you.
Priyank
Priyank Shrivastava
sorry for the delay.
The command sort of "worked".
Apache will not start.  I have been trying to diagnose
the problem.
It appears to be an error with the mod_jk.conf file.
Log states that apache can NOT write to a file.
wsconfig.log
      at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.restartWS(ApacheInstaller.java:595)
        at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.installConnector(ApacheInstaller.java:324)
        at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.installConnector(ConnectorInstaller.java:432)
        at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.doIt(ConnectorInstaller.java:372)
        at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.main(ConnectorInstaller.java:887)
[Thu Jul 13 11:37:29.104311 2017] [auth_digest:notice] [pid 27576] AH01757: generating secret for digest authentication ...
[Thu Jul 13 11:37:29.106949 2017] [lbmethod_heartbeat:notice] [pid 27576] AH02282: No slotmem from mod_heartmonitor
[Thu Jul 13 11:37:29.266555 2017] [mpm_prefork:notice] [pid 27576] AH00163: Apache/2.4.6 (CentOS) PHP/7.1.6 configured -- resuming normal operations
[Thu Jul 13 11:37:29.266644 2017] [core:notice] [pid 27576] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Thu Jul 13 11:37:35.031354 2017] [mpm_prefork:notice] [pid 27576] AH00170: caught SIGWINCH, shutting down gracefully
[Thu Jul 13 11:38:11.892368 2017] [core:notice] [pid 27644] SELinux policy enabled; httpd running as context system_u:system_r:httpd_t:s0
[Thu Jul 13 11:38:11.895152 2017] [suexec:notice] [pid 27644] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Jul 13 11:38:11.895388 2017] [jk:error] [pid 27644] (13)Permission denied: mod_jk: could not open JkLog file /opt/coldfusion2016/config/wsconfig/1/mod_jk.log
AH00016: Configuration Failed
the problem.
wsconfig.log
at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.restartWS(ApacheInstall er.java:595)
at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.installConnector(Apache Installer.java:324)
at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.installConnector(Con nectorInstaller.java:432)
at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.doIt(ConnectorInstal ler.java:372)
at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.main(ConnectorInstal ler.java:887)
Adobe Employee ,
I can see that SELinux is enabled in your server. Please check the ColdFusion lockdown guide for more details about the SELinux. TO fix this problem, you have to make a manual change.
Go to /etc/httpd/conf/ and open mod_jk.conf and comment the "JkLog file /opt/coldfusion2016/config/wsconfig/1/mod_jk.log" and start Apache. It will work.
Priyank
Priyank Shrivastava
Jul 17, 2017 Jul 17, 2017
Hello,
I have disabled the firewall and selinux.
I now get connection reset, everytime I access the page.
I look through the error logs and in message:
AH00052: pid 16454 exit signal Segmetation fault (11).
repeated over and over.
It seems like there is a problem with the either coldfusion or java.
The only thing I am programing in is Coldfusion.
Any ideas?
Brian Erickson
Hello,
[core:notice] [pid 12395]  AH00052: pid 16454 exit signal Segmetation fault (11).
Any ideas?
Brian Erickson
Adobe Employee ,
Hi Brian,
Can you please contact me at cf.install@adobe.com and mentioned this forum thread.
Priyank
Priyank Shrivastava
Jan 14, 2019 Jan 14, 2019
I have the same issue. Was this resolved?
Adobe Employee ,
Could you please let me know the ColdFusion version and OS. Also please share the complete error.
Priyank
Priyank Shrivastava
Greetings.
CF Version 2016 Standard, all 7 hotfixes.
OS is Cent OS 7 ( RHEL 7 ) with all updates.
I had the same sequence of events as above. Now the browser is just saying "The connection was reset". I can't find any specific errors.
CORRECTION, I am seeing: AH00052 child pid (20697) exit signal Segmentation fault (11).
JW
Jan 20, 2019 Jan 20, 2019
UPDATE :: Solved by disabling SeLinux.
JW
Feb 07, 2019 Feb 07, 2019
I was having the same issue on Red Hat 7
You don't need to disable SeLinux though. If you follow this lockdown guide, it shows you what permissions and what SeLinux options to change.
http://wwwimages.adobe.com/content/dam/acom/en/products/coldfusion/pdfs/coldfusion-2016-lockdown-gui...
Hopefully that will work for you if you'd like to keep SeLinux enabled.
PG
Thanks! Good to know. Must have missed that line.
Documentation
