When I toggle the visibility of a layer off, it also toggles the solo off—which by itself isn't a problem. When I toggle the visibility back on, however, the solo doesn't toggle back on with it so, so the layer stays hidden. Below is video demonstrating. I don't remember this ever being the case, i.e. I was always able to toggle the layer's visibility with that one click, so I'm assuming I'm in some mode where this is the behavior, how do I get back to the default?
Video: http://rawbee.com/random/bad-toggle.mov
Robby
After Effects 14.2.0.198
MacOS 10.12.5
Have you got all the solo switches ON? - that is with the white dot showing?
...then I would expect to see that behaviour.
In normal use all the solo switches should be OFF - blank.
I see that all the way back to CS6 the behavior is the same - if you toggle the visibility off, the solo turns off too and does not come back if you toggle the visibility back on.
That's what it was. One of them must have gotten toggled at some point. Thank you!
