Photoshop Brush not working
Jul 13, 2017 Jul 13, 2017
Simply put, the brush just stops working. It doesn't matter if it's the brush or pencil, it will not wright. I'm in the right channel, nothing is selected, correct layer, reset tools, everything. The brush will work if I restart Photoshop, until it stops again. I'm not 100% sure what stops it from working. Latest time it stopped working after I drew a simple shape and copied it several times. Help would be appreciated, I'd rather not have to restart Photoshop every 5 minutes.
3.8K
Adobe
Engaged ,
I'm not sure what the problem is but try resetting all the Photoshop settings to default.
As soon as you click to start Photoshop, Press Ctrl Alt Shift (Command Option Shift) and then click OK to delete settings file.
This will set Photoshop to the default settings. If this doesn't work, then you at least know that it is not a setting that you accidentally enabled.
Jul 14, 2017 Jul 14, 2017
Restarting Photoshop on its own temporarily fixes the problem, but then it just happens again sometime later.
Are you using a Wacom tablet? This could be an issue with the driver of the tablet. Try to disconnect the tablet. If the issue is solved reinstall again the Wacom drivers
I am using a Wacom Cintiq. But neither the pen nor the mouse can draw a line when this happens.
