I have the standalone version of LR6 and have used it successfully for some time. Now, when I attempt to open the program, the title screen opens, but I get a message that "LR is not responding" when I attempt to go beyond that. For example, I cannot even get the File button to do anything. Would it be possible to simply reload the program?
Which version of Windows 10?
How to Find Out Which Build and Version of Windows 10 You Have
Did you do any Windows updates before Lightroom failed to start?
Have you tried re-setting your Preferences?
https://www.lightroomqueen.com/articles-page/how-do-i-reset-lightrooms-preferences/
Which operating system are you running?
Windows
Windows 10.
I think so
It is "windows 10 home"
Version 1607
Os build 14393.1358
OK, thanks.
Try re-setting your Lightroom Preferences per the steps given in the link above.
I will try that. Thanks
Sadly, it didnt work. I successfully accessed the command to reset
preferences, said yes, selected a catalogue, the opening screen appeared
but the catalogue never loaded. When I clicked on File, or Library, it
said LR was not responding. I got the sam response when accessing an older
backup catalogue, so I dont think that is the problem. I found that
several of my most recent catalogue and backups carried the lock file. It
had not apparently been removed when the program was shut dowm. But going
back to a version of the catalogue that did not have the lock file also
didnt work.
