Hello everyone, today I found a problem at work. I first saved an AI file, open it in AE, select the synthesis and found that it is not sub-layers, I know that I AI file is not divided layers. But when I back to the AI layer out, go back to AE import. There is still no layer. I tried for a long time and found that only change the name and then import it can work properly.So is this bug? Or where do I understand that there is a problem.
That seems really odd. I would recommend filing a bug report here. Make sure you link to this video in the report.
Hi WiFi,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
