Integrating AOP with AEM
Avatar
Level 1
Hi Team,
I was looking for the "Integrating  AOP with AEM",
I have a project for which an extra set of Loggers are required like getting the method execution time and name of the methods which are being called .
Is this possible ? If Possible please let me know the other ways to get loggers .
thanks,
Keerthi.
Avatar
Level 10
Here is a community blog that will point you in the right direction: Integrating Spring AOP with AEM | TO THE NEW Blog
Avatar
Level 1
Thanks for the reply Scott, I have followed the same steps but could able to achieve it.
I have commented in the same site couple of weeks ago but didn't get any reply.
After following the article I could resolve the dependencies and errors but the LoggerAspect.java(the interceptor not getting invoked) class is not getting called .
Could you please suggest me on this .
I have also followed couple of other methods like
ref : Idea Fountain: Demystifying AOP, Getting started with LTW (load time weaving)  - aop.xml is not getting invoked.
Keerthi.
Avatar
Level 10
Well using Spring framework is not typically best practice.
I would recommend using logger available with Sling.
Apache Sling - Logging
Avatar
Level 1
Yes sure Scott, i was thinking of doing with normal aspectj aop which doesn't require spring..
i need some data like method name , method execution time etc logged in the logs for maintenance purpose for this i'm thinking of aop.
Keerthi.
Avatar
Level 9
Implementing AOP should not be a problem. However, Simple Sling Request Filter & Response filter might be helpful. Not sure how much Sling could be useful to solve your problems.
Jitendra
Avatar
Level 1
Thanks for the reply Jitendra, i couldn't achieve it through Sling.
Can you please suggest me how can i Implement AOP with AEM, I have noted the references which i have followed.
Keerthi.
