i am opening my lightroom application to import images. The import dialog box is opening and reading the card successfully although no images are showing. How could this problem be fix? I have work for a client need immediately. this problem is new to me.
It appears you are importing using a USB cable from the camera. Unfortunately this is not very reliable with Lightroom (don't know why) and a typical way to solve this is to just use a card reader. They are way faster and more reliable than using the camera as a card reader. Also one of the main annoyance is that OS X will automatically open the photos app when you connect a camera or card. You want to disable that as it messes up the import process. This is done in the image capture app. It is
...Copy link to clipboard
I'm not understanding this, if no images are showing then how do you know it is reading the card successfully?
Please show us a screen capture.
Can you see the files on the SD card using Mac Finder or Windows Explorer?
Yes I can see the files in Mac Finder, and Adobe Bridge it just not in Lightroom.
Before you go out and by a card reader, try this:
The Destination Panel on the right is not shown. Right click in the middle of the words File Handling and select Destination from the dropdown menu.
Here is A Snapshot. You can see the SD card on screen but there is no files being showed in the window screen.
It appears you are importing using a USB cable from the camera. Unfortunately this is not very reliable with Lightroom (don't know why) and a typical way to solve this is to just use a card reader. They are way faster and more reliable than using the camera as a card reader. Also one of the main annoyance is that OS X will automatically open the photos app when you connect a camera or card. You want to disable that as it messes up the import process. This is done in the image capture app. It is a really annoying default behavior that Apple builds in. For now what you should do is to copy the images onto your hard disk in finder or image capture and then import from your hard disk (you can use move to organize the images and not double your storage requirement) instead of from the camera.
I second the recommendation of a card reader.
In the Import dialog, open the Destination panel and make sure it is pointing to where you want/expect.
Did you ever figure this out? I'm having the same issue
Hello, I am also having the same issues, have not been able to import photos into lightroom.
I have checked all my setting to see if I could find any changes that may have occurred, nope.
The photos can be read in Photoshop and Bridge, can they be imported now into lighroom?
A bit of help to get back on track would be greatly appreciated.
I have a similar problem.....card readers for my XQD cards are no longer working to download photos... i have purchased two new ones and neither work.... no problem downloading from the camera ...without changing any settings... I am at a loss to figure out what has chnaged
