hello there guys!
I found some nice Audio effects but I don't know the commands...
Can anybody help me how to get those effects?
Camera shake: NightcoreReality & Zero.Miz-Kun - Rock Nightcore Mix - YouTube
Audio wiggle: Nightcore - God Syndrome - YouTube
there is also another nice effect I would like to know how to create but sadly I couldn't find any good examples yet. it basicalli is a rgb glitch reacting to the Audio Amplitude.
I appreciate all answers no matter if it's just a link to a tutorial or a text!
Camera Shake. look under Windows > The Wiggler. play with that till you get an image shaking the way you want it. and turn on motion blur.
audio wiggle. apply a wiggle expression to your images position and then pickwip the expression's amplitude to the audio amplitude you want to control the wiggle.
RGB glitch is the same as audio wiggle except you do it to 3 different layers and on each layer you put a Set Channel effect, set the value of the layers to Red, Green and Blue respectively, and then
...Copy link to clipboard
When you say audio effects, are you talking about making the sounds or are you talking about making the visuals react to the sound?
I mean the visual effects
RGB glitch is the same as audio wiggle except you do it to 3 different layers and on each layer you put a Set Channel effect, set the value of the layers to Red, Green and Blue respectively, and then set their blend mode to Add.
Thank you thoughtthelaw your answer really helped!
