Hi all! This is probably a simple thing, but I can't figure it out. You know how can adjust one character up and down using the baseline shift? Is there a way to do that... except from side to side?
I have an agenda with a start time, a dash, and end time and the event. The start time, end time and events are tabbed so they all line up. But I can't do that with the dash between the start and end times because I want it centered... and those spaces vary depending on the time. So I'd like to scoot that dash a little left or right so that visually it looks like it's centered.
I've attached a screenshot that shows what it looks like with invisible characters turned on (left) and off (right).
I was just adding spaces after the start times and that works for the most part. But I thought maybe there was a more elegant way of doing that, as it is not perfectly centered when I do that.
Also, I just realized that in the example image, the start times all sort of line up. But that isn't the case throughout... some are quite a bit longer than others.
I'm using InDesign CC on my iMac. Thank you!
Set another tab before the first one, make it center aligned, then type it before each dash (and get rid of the space after each dash).
If I wanted the dashes lined up, I would use a center-aligned tab for them.
Mike
Thank you both for your quick responses.
So if the text is not so complex(involving images, footnotes etc) you can add the text in a table. That would be the easiest way to align the dashes. You can add start time, dash , end time and events in separate columns. The columns with the dashes can be aligned centrally and made a little smaller in width thatn the rest.
Well this is just a quick hack.
-Aman
Thanks, Aman. I did that elsewhere in this program... but it didn't occur to me do it in this case. Tables are always helpful!
