Out of the clear blue, Adobe Acrobat XI stopped communicating with scanning device which is HP Office Jet 8600. I tried many things using research results from the web but no luck. I updated the software and still not luck. I removed printing device and re-added, still no luck. Does anyone have a solution.
Hi steveng21921440,
We are sorry for the bad experience with Acrobat scanning feature.
Would you try suggestion mentioned in this link: Troubleshooting tips for scanner issues when using Acrobat
And if I understand correctly Acrobat suddenly stopped to scan from the same scanners it used to detect and scan from? If the above steps don't help, you may try uninstalling Acrobat using cleaner tool: Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs restart your machine and try installing Acrobat again. Check if that helps.
If you already have found a solution to this issue, please update this thread with your findings that will help others.
-Tariq Dar
[abuse removed by moderator]
