SOLVED
Not able to make use of SlingHttpServletRequest in Sling Model in AEM 6.3
Avatar
Level 8
Currently have a model class with @Model(adaptables = Resource.class). The code written so far works absolutely fine.
To this , I have now added the below
@Model(adaptables = { Resource.class, SlingHttpServletRequest.class })
   @Inject
    SlingHttpServletRequest request;
as I want to make use of request Object in my code.
Referred multiple links on this, Few examples :
https://www.slideshare.net/AEMHub2014/sling-models-by-justin-edelson-final
http://www.wemblog.com/2014/11/how-to-use-sling-models-in-cq56.html
https://forums.adobe.com/thread/2329143
But still not working. " Identifier xysdkfjk cannot be correctly instantiated by the Use API" is the error I keep getting.
Any thoughts on this will be helpful.
1 Accepted Solution
Avatar
Correct answer by
Level 10
Avatar
Level 5
You can achieve sling request object by different ways :
@Self
private SlingHttpServletRequest slingHttpServletRequest;
By Constructor
@Model(adaptables= SlingHttpServletRequest.class)
public class TestModel {
  private final SlingHttpServletRequest request;
  public TestModel(SlingHttpServletRequest r){
          this.request = r;
By Name
private SlingHttpServletRequest request;
Avatar
Level 8
Hi zeeshank15007365,
Thank you for your reply.
To get the request Object to my existing class which is working fine, I did the below :
1] Added request to adaptables which just had resource earlier : @Model(adaptables = { Resource.class, SlingHttpServletRequest.class })
2] Tried with
@Self
and
By Name
but no luck. Not sure what is it that I am missing.
Will try the constructor method too and let you know how it goes. Thanks again for replying on this query of mine.
Avatar
Correct answer by
Level 10
Avatar
Level 8
The snippet shared by Feike doesn't help me with the use-case I have.
Avatar
Level 10
Feike Visser​ - can you look here when you can - thxs
Avatar
Level 10
Where you able to succesfuuly compile this code? I have never tried to make use of a Request object in a Sling Model. Only a Sling Servlet. What are you trying to do?
Avatar
Level 8
Hi Scott/Feike,
In component model class, was trying to get request object to use for api resolver.map(). However, now using resolver.map that takes in a single argument rather than the one along with request.
However, it would be helpful if you can let us know how can we take request object in Component model class[in case we need it sometime in the future.]
